Author Topic: engine noise  (Read 4989 times)
fightingtorque
engine noise
« on: June 22, 2008, 09:26:46 PM »
Engine is qiet when cold but quite a rattly thing when warm.  I have set the valve clearances, didn't affect it.  Doesn't sound like big end noise (have had that before), maybe they are always noisy?  What would you experts say - is it quite a noisy engine (This is a Bis watercooled).
Doesn't smoke and hasn't used oil (in the 130 miles since I bought it).
Going to flush it, put new oil in anyway.
Cheers,
Gav
engine noise
« Reply #1 on: June 22, 2008, 10:08:38 PM »
the only rattles you could get are the front or rear main bearings or the exhaust or brackets coming loose . is it on the slack revs or all the time when hot?
fightingtorque
engine noise
« Reply #2 on: June 23, 2008, 01:08:51 PM »
I'd say its just noisy all the time.  Not like big ends which have a characteristic clunk particularly as you accelerate the engine.
Re: engine noise
« Reply #3 on: December 18, 2008, 09:46:58 PM »
We were messing with a BIS the other day and set the tappets to 10..dunno but thats what is written on the feeler.
Blimey it sounded good!
Going to give my air cooled the same treatment and see what happens because mine is as you described, noisy when warm.
phreak97
  • Niki!
Re: engine noise
« Reply #4 on: December 19, 2008, 03:21:10 AM »
i'd never thought of that.. what can be achieved by playing with the valve clearances? any performance increase?
phreak97
Re: engine noise
« Reply #5 on: December 19, 2008, 08:57:06 AM »
Valve clearances that are set to tight can cause the valves to burn out  :oops:
Best to stick to the manufactures setting [-/
Cold engine
Inlet .20mm .008"
Exh  .25mm .010"
Re: engine noise
« Reply #6 on: December 19, 2008, 09:36:39 AM »
I was thinking...am I supposed to be running lead replacement in me air cooled?
It's a B reg...'84 I think.
test1234
  • Guest
Re: engine noise
« Reply #7 on: December 19, 2008, 10:58:48 AM »
either use a customised unleaded head or a good lead additive for mixing into the petrol.
Re: engine noise
« Reply #8 on: December 23, 2008, 05:43:36 PM »
set my valve clearances...still noisy
thought maybe the rattle is from the fuel pump rod being a bit loose, dunno think they are just noisy!
Re: engine noise
« Reply #9 on: December 23, 2008, 06:09:43 PM »
They are a noisy engine and you'll never get it sounding like a modern day engine :D I've reset my tappets a couple of times but they still tap ;D
Re: engine noise
« Reply #10 on: December 23, 2008, 06:14:43 PM »
I wish we had a resident guru on engine noises so we could pin point what is making the noises and try to reduce them.
All in all the engine is brilliant, I mean a 650cc air cooled engine capable of pushing a car with 4 people in at a fairly respectable rate.
Considering the age of the original design of the engine.
I just wish the only noises coming out the back were exhaust noises!
Re: engine noise
« Reply #11 on: December 23, 2008, 06:37:26 PM »
I think its just the design of the engine some OHV engines like the old Datson micra were as sweet as a nut but the Ford OHV used in Fiestas/escorts always sound like a bag of old nails ;D
Re: engine noise
« Reply #12 on: December 23, 2008, 10:02:38 PM »
Hmmm an observation on Axel gerstl website reveals that one should look out for a noisy camchain ....
I wonder...
Re: engine noise
« Reply #13 on: December 24, 2008, 09:50:20 AM »
darrel what sort of noises are you getting? i have had some experiences similar to you and have so far had noises because ...rattly squeaky sound lol from exhaust to manifold bolts getting loose, exhaust brackets fracture and rub against eachother and make a very loud tinny noise , tinwork on the fan side can deteriate inside and become loose which with vibration makes a very harsh noise which sounds like its coming from the engine, alternator bearing deteriated and makes a grumbling noise (if you can imagine what that is!!). broken piston ring which sounds like a bag of spanners!! (for this a compression test will tell you, if you suspect it), if you have a after market exhaust with a perforated baffle they can come loose inside and make a metalic ring as you rev...well cheap ones do..lol , main bearings front and rear can become noisy this is an obvious noise as you can detect where its coming from easily. thats the engine . any other noises from the rear can be gearbox/diff all sorts of grief!! driveshaft splines worn , rear hub bearings worn . mounts on gearbox kaput,  broken rear engine mount spring or worn rubbers . also you can have worn rear suspension rubbers which let the struts move around and sound like your fuel tank is making a clunking sound . with all these potential sounds to tease your ears its advisable to just go deaf and wait until the engine or offending bit falls off then its blatently obvious which area to repair!!
fightingtorque
Re: engine noise
« Reply #14 on: December 24, 2008, 11:50:58 AM »
It's a little unusual to have a pushrod engine with an aluminium block and head.  The expansion rates of the aluminium castings are different (more) than the steel parts of the valvetrain, so the clearance probably increases as the thing warms up. Of course the temperatures of the parts are potentially different as well, so it's a bit complicated, but I think that is what causes the thing to sound so tappety.  I have heard that on the aircooled the exhaust clearance reduces quite fast with wear, leading to the valve not sealing when cold and difficulty in getting the engine to start, but this was just one former owner told me it.
I think this issue is also perhaps the reason why a poor fuel pump operation on (a BIS at least) doesn't show up until the engine is properly warm.
If you let the clearances get too small when hot, and you have leakage past the exhaust valve, you will burn it out.  Tried and tested way to kill a hillman imp engine some years back.
On the power optimisation, I believe there is a view that a tight clearance on exhaust can help by giving the maximum opening period, but can be detrimental on inlet because you lose that sudden opening and closing of the valve, but this was comment from dave vizard in his excellent book an BL A-series engines (Minis etc) and may not always apply.
Since I made the original comment I have had to replace the bottom end of the engine for another reason (a washer went through it) and the noise is still the same, so I am sure it is just the general noise of this engine type.  Not intrusive to the driver, but noisy from the outside.
Happy christmas 126'ers.
Gav
