Author Topic: engine noise  (Read 4989 times)
Re: engine noise
« Reply #15 on: December 24, 2008, 04:40:49 PM »
Hi guys, sorry to be a pest on this subject however I am on a bit of a quest.
If I achieve my quest is yet to be seen  :)
So today the wife was away at work and decided to spend the whole day fiddling with my bug.
Valve clearances were suspected and on the advice of the forum they were set to 10 and 8.
Engine started and warmed-up and to my horror the sodding things had opened right up so re-set to 10 and 8 with a warm engine. Sod it I figured! It spends more time warm than cold so if I burn a valve then I'll have to get a Panda 30 head etc etc...cunning way to get that past the wife..
The noise was still there after all this. SOunds like a loose tappet coming from somewhere around the fuel pump.
Eurika I though, and in the words of my ex boss, if it bothers you cut it off! So off came the pump and a blanking plate fitted. manual operation of the pump was required by my now very tender thumb. Alas the tappety noise was still there...
So I thought maybe there is a follower on the end of the rod that works the pump.
Blanking plate was removed, pin inserted and to be honest the pin moves so slowly compared with the revs I doubt it is that. Anyhow to be sure, I machined some of the stuff off the spacer leaving no gap to much around with.
I thought about the altonator and removed the belt. The altonator seems to spin freely and even with a bit of back and forth there is no noises. Ran the engine with no belt...the noise is still there...
So I am back to my original thoughts of cam chain.
I'll find this sodding noise! Even if it means I have to re-design something! But don't quote me on that as I may give-up and get distracted by somthing else.
And believe me I'd rather be thinking of noises right now from the car as my mother in law is here for xmas! :-
Fitted the double coil from a BIS to it and I can feel the benefits. It doesn't 'miss'
Accelorator cable bit near the engine removed and lubed and now I have a diferent car!
I suspect my rubber goodies on the end of the drive shafts are knackered as the layman's test was to jack-up one side of the rear of the car, place it in gear and turn the wheel.
On observation of the drive shaft, that moves quite a bit but stops at a point. Turned the wheel one way and it seemed to be all nice and rubbery once the driveshaft stopped, a nice firm rubbery feel the type one would expect from Pamela Andersons..... Turned the wheel the other way and there is a bit of a squidge then a tap... which probably translated to a clunk with the masses of horsepower from my beloved bug.
The noise I am trying to solve is when the engine is running, it is there regardless.
I suspect I might be trying to solve the fiat 126 noise..
Re: engine noise
« Reply #16 on: December 24, 2008, 07:01:09 PM »
Yes, timing chains can become noisy after a while. Have you checked the metal engine covering below the engine (has slits on it that directs air)? The screws might come losse and the cover may rattle. Try moving the engine block when it isn't running. Mine has a squeaky sound, because the main spring (that suspends the block) has a rubber cover which has ripped, and rubs against the spring.
Re: engine noise
« Reply #17 on: December 25, 2008, 01:01:56 PM »
Perhaps you are not setting the valves correctly?
It also may be worth investing in a Mechanics Stethoscope they only cost a few quid
Re: engine noise
« Reply #18 on: December 27, 2008, 07:08:34 PM »
Quote:"It also may be worth investing in a Mechanics Stethoscope they only cost a few quid"
Or you can use a screwdriver (place your ear to the end of the handle, you'll be surprised the stuff you can hear.) :)
phreak97
  • Niki!
Re: engine noise
« Reply #19 on: January 05, 2009, 03:24:13 PM »
my friend's car has a bit of an unhappy rattle noise from the engine, havnt done the valve clearances yet though.
is your oil cap tight? i have to turn mine only half way, cos after that it loosens off again and if left there produces a rattle with the engine movement. though you've had the rocker cover off a few times so you probably would have noticed that.
phreak97
Re: engine noise
« Reply #20 on: January 31, 2009, 04:50:29 PM »
Just to confirm I have learned something from playing with engines for 23 years. I have done and re-done the tappets on the air cooled, the noise I heard was not tappets. Seems everything is blamed on tappets.
This weekend replaced the camchain and wow what a diference!
No rattles...at all.
I can now hear the whirl of the fan and exhaust note only with a little wine from the altenator.
How long this will last will be interesting as they do not have a cam chain tensioner, only time will tell.
So sweet does the engine now sound I shall be purchasing another cam chain set with the sprockets, just so I know I can return this lovely sound to this engine.
PS to hell with the manuals! I set my clearances engine warm. Even in this weather is stays cold how long? I checked it cold and there is still clearance, just a little smaller.
A trip to Kent from Southampton with my foot virtually flat all the way back and no dreaded valves burnt or clouds of smoke.
Basically regular oil changes and oil filter clean outs are my motto.
It is an air cooled and travelled at between 65 and 75 mph. It seems to run even better now, as if the crud has been blown out the exhaust!
Mick does the same and from his experience it's not all doom going over 60 provided all is sound.
This is my experience and will not take responsability for following this as I may just have a really good engine.  [-/
Just glad I have got to the bottom of my noises in my engine. :oops:
Re: engine noise
« Reply #21 on: January 31, 2009, 08:10:22 PM »
hhmmm... good post Darrell, i wonder if it would work on a bis...  :oops:
Re: engine noise
« Reply #22 on: February 02, 2009, 11:06:50 AM »
darrel nice to know youve found it ! i still havent put my refurbed engine into the polski and dont care if the current one sounds like a bag of spanners it works and thats fine by me! i might invest in an aluminium fan as they are cast and so dont bend up and sound like the stock one does i hope!
Re: engine noise
« Reply #23 on: February 02, 2009, 11:44:56 AM »
Hi Mick,
I'll be very interested to hear your experience with the ally fan as I have been looking at them with big eyes.
One is on my wish list  [-/
