can you pull the starter out and adjust it so it starts the motor spinning just before it meshes? like one mm away from the flywheel or something? when you pull the lever it should start the motor just as it hits the flywheel and then itll slot the rest of the way in once the teeth align.
if anyone thinks this will cause alot of damage, say so, i'm just making theoretical solutions in my head.. starters have always just worked for me:P
how does one usually mesh? are the sides of the teeth V shaped so that theres no flat edge to hit?
is your flywheel the right way around?
honestly i dont know if it's possible to go on backwards, i've never had one off.
