Author Topic: Flywheel? Starter? odd problem...  (Read 4103 times)
« Reply #15 on: June 28, 2008, 10:01:27 PM »
just an idea do you have this plate installed on the starter motor? if it's missing you may have problems!
« Reply #16 on: June 29, 2008, 12:13:55 PM »
if it is the cable causing the problem then its down to the cable stretching . i had this problem with my black polski and replaced the starter cable with some steel wire rope and used some tiny clamps to make a loop , it takes a bit of experimentation to get the right length but once its done it will last a sight longer than the thin cable that does the job now , if you do this just remember to make sure the cable does not come into contact with the bodywork.or use a cut down broom handle and start from the rear!
