Poll
Is the Disc brake conversion worth it?
Totally!
7 (63.6%)
No, not really..
3 (27.3%)
Dont see the difference..
1 (9.1%)
Total Members Voted: 11
Voting closed: May 06, 2008, 01:22:06 PM
Author Topic: Disc brake conversion, is it worth it?  (Read 5663 times)
« on: May 06, 2008, 01:22:06 PM »
Im just wondering if all the money and time spent into converting drum brakes to disc brakes is worth it? The car doesnt have servo asisted brakes, so its equally difficult to push the pedal one way or the other. so what do the disc brakes offer that drums dont (on the 126, not in general :)) I have changed all the replacable parts on my drum brake system, and she brakes and stops like a charm...
all info and opinions are welcome. Thanx.
Gordan.
« Reply #1 on: May 07, 2008, 05:44:23 PM »
the disc setup is a far superior way of braking than the drum sort, they offer better cooling of the friction material ( a big weakness of drums is they overheat ) their also easyer to maintain ( less moving parts ) and a pair of pads "squeeing" a rotating disc is more efficient at stopping than two shoes expanding........their just better  :D
« Reply #2 on: May 07, 2008, 06:33:47 PM »
Cheers mate, thx for your reply. But all that you said is bassically general knowledge, but im interested apart from the heat factor, what do they offer to a car like the 126. I know that disc brakes are supperiour to drums, and that is why wee see them on the modern cars and not drums, but you go through all the trouble buying these sets, making them work, and worrying if theyre set up correctly all the time, and you still have to put 2 tons of pressure ( :D ) on the pedal, and you stop in the same distance as a drum braked 126. (I can block my wheels with no prob)...
This is why i asked the question in the first place, just trying to get informed if its worth it, so i might put it on my bis one day..
Cheers. Gordan
Maddog
« Reply #3 on: May 07, 2008, 09:51:05 PM »
nothing wrong with the stock drums on a stock engined car, after all they only have to reign in a 600kg car with 26 or 30 BHP. as long as they are in good working order then why change them
« Reply #4 on: May 09, 2008, 10:33:53 AM »
There have been days where I come off the motorway doing 80 and the traffic sortof slows down very quickly...that is when I wish I had discs!
Suppose I shouldnt be doing 80 but then I suppose I shouldn't do alot of things  :cool:
hudsonhenry
    • http://www.retro500.com
« Reply #5 on: May 10, 2008, 09:10:11 AM »
A lot of race cars have a non servo disk brake set-up, they get the power of disk brakes, but removing the servo gives more feel at the pedal.
Ok so you have to push harder with no servo but given the same pedal pressure with a disk brake set-up against drum brakes the disks will always stop shorter.
rockchevy85
    • http://myweb.tiscali.co.uk/camaro/bambi
« Reply #6 on: May 19, 2008, 11:29:49 PM »
Quote from: hudsonhenry
Quote
Not only do you get more feel, but in terms of racing a servo-assisted brake has a noticible delay before disengaging after the pedal is released, as opposed to a non-servo which releases instantly.
phreak97
  • Niki!
« Reply #7 on: May 23, 2008, 03:27:12 AM »
i dont see the point, one of the things i love about my niki is the shorter stopping distance over my other cars, and i'm on stock brakes..
why fix something that isnt broken?
on the other hand, my morris 1100 has discs on the front from the factory, and it's a b******* to stop..
phreak97
« Reply #8 on: May 23, 2008, 12:06:25 PM »
It has shorter stopping distance?? What other cars do you have? a ford model T  :?:  :D  I have to drive at least a few meters behind the car in front of me just to be able to stop behind him, not on him  :lol:
and my whole brake system is brand new (well, only the pipework is orig... )
phreak97
  • Niki!
« Reply #9 on: May 23, 2008, 01:07:52 PM »
morris 1100 s, cm valiant (chrysler regal), fiat topolino, and a mitsubishi sigma, though that possibly stops quicker.
phreak97
« Reply #10 on: May 23, 2008, 01:41:33 PM »
well, the 126 is probably more advanced than most of your cars, but compared to todays cars, it stops from 100km/h in what 100 m?  :D
phreak97
  • Niki!
« Reply #11 on: May 23, 2008, 11:36:39 PM »
well i dunno.. i could lock up the brakes if i wanted.. so shouldnt the stopping distance only be limited by how hard you push the pedal?
phreak97
« Reply #12 on: May 24, 2008, 12:10:27 AM »
yeah, i thought so too, thats why i started the topic, but it turns out no...
« Reply #13 on: May 24, 2008, 01:04:37 AM »
It all depends on where you live and how you drive, the drum setup is quite adequat for normal town driving the only problem is when you have to stop quickly from motorway speeds or long downhill sections in traffic where you have to use the brakes constantly, the drums and linings get hot and you loose braking due to brake fade the heat also transfers to the brake fluid which can boil. where as discs don't fade in normal use and cool down quicker, so they are safer.
« Reply #14 on: May 26, 2008, 08:14:19 PM »
Yeah I do alot of motorway driving (when it is on the road) and as I said before I have done alot of praying.
There have been days I get cocky and close down the gap to an acceptable gap for modern cars, the traffic comes to a hault so I slam on brakes and the car violently swerves from side to side.
Somehow it has always stopped just in time with the occasional close-up's of the boot lid of the car in front.
I plan to do the following:
Disc brakes
Braided hoses
Higher DOT rating fluid and toying with the idea of a servo but then see how it goes with the discs etc.
I figure a 126 is never going to be a speed demon so might as well make it handle like on rails and stop very quick.
