Poll
Is the Disc brake conversion worth it?
Totally!
7 (63.6%)
No, not really..
3 (27.3%)
Dont see the difference..
1 (9.1%)
Total Members Voted: 11
Voting closed: May 06, 2008, 01:22:06 PM
Author Topic: Disc brake conversion, is it worth it?  (Read 5663 times)
« Reply #15 on: May 26, 2008, 10:35:08 PM »
Quote from: "Darrell"
There have been days I get cocky and close down the gap to an acceptable gap for modern cars, the traffic comes to a hault so I slam on brakes and the car violently swerves from side to side.
This happened to me twice, so i decided not to go fast ever again... :???:
phreak97
  • Niki!
« Reply #16 on: May 27, 2008, 12:35:17 AM »
we dont have motorways as such, so it's hard to compare.. but on the few occasions where i've had to stop quickly my car has never swerved at all.. perhaps your stock brakes are not all that happy? mine's only 18 years old afterall.
if you want a scary experience, drive a topolino on original specification tyres like mine (very thin, and made from hard rubber) the wheels lock and the car keeps going.. last time i took it out, approaching an intersection the lights went orange, i was too far away to reach it before it was red, with plenty of distance to stop (i thought) but i ended up screeching to a stop just over the line anyway.. i think im going to have to get it looked at by a professional. lol
thats the other thing.. i have all new tyres, i think theyre probably a big factor, theyre also 135sr12's like it says in my book, i dont suppose any of you have those anymore.. they'd reduce the torque required from the brakes, being smaller.
phreak97
« Reply #17 on: May 27, 2008, 05:13:44 AM »
Mines 17 years old, new brakes, new tyres (135/70 13) and this happened when i was doing 80km/h downhill, the traffic stopped unexpectedly, so i started to brake, my front end went straight, but my rear end went left-right-left-right, and i managed to stop a few cm from the car in front....  :???:  (scared the living jesus out of me)
On the other hand, it was really funny watching the dude behind me drive at a distance of 10 m for the rest of the trip...  :lol:
phreak97
  • Niki!
« Reply #18 on: May 27, 2008, 09:53:19 AM »
wow.. i wonder what caused that.. it sounds pretty unusual.. try jacking up the back and checking for slack in the bearings (grab the wheel and wiggle it up and down) there could be something more than just your brakes at fault there..
phreak97
« Reply #19 on: May 27, 2008, 11:44:50 AM »
DK, but i aint messing with it any more, it drives just fine now at city speeds, stops like it should, and i figure why mess with it? I have no intention of driving fast anyway, since this could happen:
40 km/h:
S C A R R Y!  :smt119
phreak97
  • Niki!
« Reply #20 on: June 11, 2008, 03:15:44 PM »
having said disc brakes probably arent worth the money, i've got some news.
a guy i know is moving house and has been clearing out a shed full of 500 and 126 bits and has given me alot of stuff (a couple of carloads!) for free, today he gave me a used disc brake kit for free!
guess ill be finding out first hand if theyre worth it or not. they do need a rebuild, but it shouldnt be a problem.
phreak97
subvert73
« Reply #21 on: June 11, 2008, 04:03:25 PM »
Quote from: "Cro_126Bis"
I used to have a 1975 Mini that did the same thing, in fact on two occasions it actually spun through 180 degrees, very scary on a public road.
It's caused by the fact that during heavy braking the weight of the car shifts towards the front. Therefore there's less weight on the rear wheels so they lock up before the front ones. You're effectively doing the same as pulling up the handbrake so any slight turn on the steering wheel under heavy braking will have the same effect as a handbrake turn.
Rover cured this problem on the Mini by fitting an automatic brake bias unit. If you braked heavily the force shifting to the front caused a ball bearing to run up a ramp which partially shut off the brake fluid to the rear. This in turn caused both front and back wheels to lock up at more or less the same time.
This won't be so much of a problem on a 126, as being rear engined there is more weight on the rear wheels straight away. However I should think that wouldn't make much difference under heavy braking whilst traveling fast, down a hill on a wet road.
Fitting disc brakes to the front of a 126 will have a similar effect to fitting a brake bias unit such as I just mentioned. The front brakes will lock up before the rear in normal braking situations, but under heavy braking when there is more weight on the front they should lock up at a similar time.
This is one very good reason that disc brakes are better than drums.
Steve.
« Reply #22 on: June 11, 2008, 04:04:04 PM »
:smt023
phreak97
  • Niki!
« Reply #23 on: June 11, 2008, 04:22:29 PM »
i guess in this situation, but if you went and installed discs all round you'd be right back where you started, only quicker:P
phreak97
« Reply #24 on: June 17, 2008, 08:04:45 PM »
Had a 126 on discs, very agressive for road use, they were on or off, no feel at all. I only had them on the front and you could get the back 2 wheels off the ground. Fun at the lights but the novelty soon wore off.
