Author Topic: Guido the Fiat  (Read 87785 times)
0 Members and 4 Guests are viewing this topic.
Re: Guido the Fiat
« Reply #195 on: February 26, 2009, 09:38:55 PM »
Been fiddling about the little one today and heres what has been done: <brand new leather cloth door cards>
Can anyone tell me what is strange in the 2nd picture, its a detail, but lets see how good your sight is :D
Re: Guido the Fiat
« Reply #196 on: February 26, 2009, 10:27:11 PM »
yoooze got rectric windaaas....
Re: Guido the Fiat
« Reply #197 on: February 26, 2009, 10:32:01 PM »
Yeah i got it recently, but there is one particular thing on the pic which is not supposed to be that way, yet, it is  :D
SECOND PIC...  ;)
Eklipze3k
Re: Guido the Fiat
« Reply #198 on: February 26, 2009, 10:32:55 PM »
Looking very nice. As for what's wrong, is it the way the wiring's going - it's gonna make the door card bulge isn't it?
Eklipze3k
Re: Guido the Fiat
« Reply #199 on: February 26, 2009, 10:35:26 PM »
Or is it simpler than that - the buttons for the window are exactly the same - which one's up and which is down?
Re: Guido the Fiat
« Reply #200 on: February 26, 2009, 10:36:54 PM »
The card does have a lump on it, but still not the point, neither are the buttons, little more time, and ill give you a clue... ;)
Re: Guido the Fiat
« Reply #201 on: February 27, 2009, 09:58:49 AM »
well you have two plastic sheets for water protection inside rather than one and the bottom of the door has been covered with some sort of backing that looks like felt! youve filled the door up with electrics and must have a lorry battery and an alternator off a hgv !
Re: Guido the Fiat
« Reply #202 on: February 27, 2009, 10:43:12 AM »
Lool, but still wrong, you guys are short sighted just as i am (-12  :oops: ), ill let you in, you see those two wires, the yellow and the pink one? well its logical that the pink goes into pink and yellow to yellow, but once i connected them that way and assembled the door i found that the up button takes the window down and vice-versa. so take it all apart again and coonect it the wrong-right way :D
Re: Guido the Fiat
« Reply #203 on: February 27, 2009, 03:16:49 PM »
so you mean electrical plug is not idiot proof! lol
Re: Guido the Fiat
« Reply #204 on: March 01, 2009, 01:25:28 PM »
Problems, problems, problems.... where would we be without problems. Now my 2 cyl is leaking oil all over my freshly painted exhaust... does anyone know what could be causing it? it started when we re-tightened the cyl head after the head gasket change, the tappets were re done (but apparently not the way they should, there is a clicking sound coming from the engine which wasn't there before)
and everything was put back into place. thing is there was very little oil round the tappets when we first took the engine apart, and now it is leaking en-masse...  :o :o :(
i suspect the seal round the tappet cover is cr@p, so ill replace that, but could it be something more sinister...  </6 :oops:
Re: Guido the Fiat
« Reply #205 on: March 02, 2009, 07:37:39 PM »
When you replace the rocker gasket check that the oil feed pipe to the rocker shaft is seated properly. I stick the gasket to the rocker cover using clear silicone then the other side of the gasket then fit. once tightened up wipe the excess off. Just a little bit of extra insurance against it leaking :)
Re: Guido the Fiat
« Reply #206 on: March 02, 2009, 07:57:27 PM »
It was the gasket after all, my bro put the damned thing on the last time, and it wasnt seated correctly, i used some locktite sealant for engines on it, its holding so far.
I must admit it was quite scary driving home from across town with oil dripping on a super-heated exhaust. I had a feeling it could ignite any moment. lucky for me it didnt. im getting a extinguisher any way...  8)
Re: Guido the Fiat
« Reply #207 on: March 02, 2009, 08:45:31 PM »
is it an electric one? lol
Re: Guido the Fiat
« Reply #208 on: March 02, 2009, 09:32:20 PM »
lol, if there only was an automatic one, id buy it for sure :D
Re: Guido the Fiat
« Reply #209 on: March 15, 2009, 03:17:48 PM »
Ive finally had my carb replaced!! Yuhuuu...  :D
The carb thats in is the one from a Citroen gs, it fits perfectly, only diff is that it has all metal parts, so this means i have a working choke finally... oh and second thing ive noticed is the increase in power, i now can go up most local hills in third, doing 60/70kmh.... it finally feels like it has some power under that boot  :D :D the engine works soo much steadier now, and makes a lot less wibrations...
All in all i would recommend this swap to anyone having carb trouble, my old one wouldnt start in cold, the car would shake a lot when cold, and used up a lot of fuel, now, it works like a charm, dont even have to use the new choke, cos it starts with just a little throtle...  :D [-/ [-/
