Author Topic: Back Camber  (Read 1277 times)
jon.hunt
Back Camber
« on: January 19, 2008, 12:53:07 PM »
    Just wondering is there an Easy way to Reduce the Back Camber on a 126 as I've just fitted New Falken 165/60 R13 Tyres to alloy wheels and I'm assuming the Outside edge of the Tyre will wear First, but as there directional tyres I cannot have them Turned round.  In fact these were the Only tyres I could get to Fit other than Nankangs and there directional too.
                                             Jon.
MaLi
Back Camber
« Reply #1 on: January 19, 2008, 01:21:47 PM »
On rear you can play with the suspension height. By lowering camber goes negative.
On the front you can set camber by adding/removing spacers under the top wishbone.
