Author Topic: air filters  (Read 3309 times)
Enzo2
air filters
« on: December 12, 2007, 08:59:55 PM »
I am thinking of swopping the air filter for a K&N type.   Anyone got any advice.
DanRodd
air filters
« Reply #1 on: December 12, 2007, 09:48:31 PM »
ill let the more knowledgeable answer,but i cant help but think that something will need modding on the cowling to keep the engine cooling as it should be.
air filters
« Reply #2 on: December 13, 2007, 07:16:08 PM »
if its a cone type just remove the air feed to the carb and using a jubilee clip fix it directly to the 90 degree pipe left on the carb. you then need to block off the original airfilter housing , or if you can be bothered remove it and plate the hole off.
MaLi
air filters
« Reply #3 on: December 13, 2007, 10:07:15 PM »
I wouldn't recommend putting it so close to the carb as:
1. You will loose bottom end torque - too short intake
2. Engine will be sucking hot air and hot air = less oxygen
Try placing it in standard place sth like that:
http://www.magsport.republika.pl/foto/strumien/126alfa.jpg
Or even better using kit like that:
http://www.magsport.republika.pl/foto/strumien/126Raylle.jpg
To allow engine to get even more air you can get rid of a restrictor in the inlet:
http://www.126fan.pl/www/dolot.htm - first photo
and/or drill holes in the bottom of the air filter box.
It really works. Ohh and don't forget to tune carb after you've done the changes.
Cheers.
Mali
Tomasz
air filters
« Reply #4 on: December 14, 2007, 09:57:53 PM »
Mali - I have a modified old school pancake filter attached straight to the top of my twin choke solex (on panda head), is this not a good idea?  Maybe i should run a pipe to somewhere where the air is cooler.  I have already removed the air filter housing.
Enzo2
thanks guys
« Reply #5 on: December 15, 2007, 08:44:51 PM »
So much good advice.  esp Mali,  Many thanks.
MaLi
air filters
« Reply #6 on: December 16, 2007, 01:33:20 PM »
Quote from: "Tomasz"
Do you have side draft carb or std Panda one?
Tomasz
air filters
« Reply #7 on: December 18, 2007, 08:56:21 PM »
std panda at the moment but i might get a dellorto dhla eventually although there is not much point until i get a different cam.
