Author Topic: Riding high  (Read 5292 times)
Riding high
« on: September 24, 2007, 03:47:06 PM »
After nearly completing my disc brake/alloys/shocks conversion, I have been left with the front of the car sitting high. The rear of the car is fine, but the front is sitting up very high. It always used to be high, but not to the extent at which it sits now - about 80mm between tyre and wheel arch.
Bar the leaf spring, I have just recently changed all the front components, including shock absorbers and fitted 13" wheels, and it is still sitting just as high.
Sandbags aside, I cant think of a reasonable solution that wont involve buying a lower front leaf spring.
I am aware that after a little drive, it should settle a little, but I cannot do this yet as have still not finished fitting the brakes.
Any help much appreciated.
Pictures to follow
Riding high
« Reply #1 on: September 25, 2007, 10:18:45 AM »
Riding high
« Reply #2 on: September 25, 2007, 10:39:50 AM »
That does look high! :shock:
I would have thought that the spring is causing the problem? but you say that has not been touched.
Have you tried disconnecting the shock absorbers to see if the correct ride height comes back, perhaps the shockers are too long?
The only other thing is the bolt for the leaf spring I think it has to be tightened with the car on the ground.
Riding high
« Reply #3 on: September 25, 2007, 12:09:50 PM »
it does some times take a while for lowered suspension to settle (altough it doesnt look like it will settle enough to be low enough)
have you consider shaving the alloy blocks, this will lose 1cm off the height..
also where did you get the spring from did they quote a lowering figure on it, Ive just purchased on from prioretti's which quote 2 and a 1/2 inches off the ride height (although it still neds to be lower... perhaps yours is just stiffened and not lowered?
Riding high
« Reply #4 on: September 25, 2007, 12:29:18 PM »
Spring is not lowered, it is still stock and I haven't touched it.
I've just changed stub axles, brakes, wheels/tyres and shocks. The ride has always been quite hight up front, but never to this extent. The stiffer new shocks could be contributing, but they can't be entirely to blame. I will try and loosen the bolts and tighten under load, and see if that helps.
Riding high
« Reply #5 on: September 25, 2007, 02:28:21 PM »
if you dont like it try sticking some rear shocks up front as they are much lower. try undoing the bolts that connect the leaf spring to the steering /suspension components whilst under load to see if it settles lower then re tighten.
Maddog
Riding high
« Reply #6 on: September 25, 2007, 11:20:39 PM »
I'd make sure the suspension moves freely as to sit this high something must be a bit on the tight side, may not be anything to worry about but you don't want to damage any of the new parts,  get up and have a good bounce up and down in boot. if everything is free it will come right back up to this height, if something is binding it will then sit too low
Riding high
« Reply #7 on: March 26, 2008, 03:08:40 PM »
My new reverse eye leaf spring came in a few days ago, the car is still sitting high, so I think I will try and get this spring fitted as soon as I can. I am also waiting to fit some smaller tyres on the front axle. I have opted for some 145 60 13s to fit on my 5" wheels.
I have previously been running 155 65s, and think that these could be contributing to the increased ride height. The smaller tyres at the front should also help reduce the scraping on full lock.
Would anyone happen to have a rough estimate of the cost a garage would/should charge to change the front leaf spring and re-track the front wheels?
I'm assuming that without specialist equipment it is not a job worth attempting myself?
Riding high
« Reply #8 on: March 26, 2008, 05:38:28 PM »
No special tools needed, just a couple of axel stands or blocks to support the spring at each end. a seasoned pro like you, should have the job done in a couple of hours :D plus you can get an extra 10mm by shaving the blocks. i'd leave the tyres.  Nice wheels though  :)  :)  :)
Riding high
« Reply #9 on: March 27, 2008, 12:07:37 PM »
Ok, maybe I will have a go at it myself.
Is there any important advice/pointers I should know before starting?
What is the most likely thing that could go wrong?
Where is the best place to put the axle stands when removing the spring and do you put it back on tightening one side at a time?
Riding high
« Reply #10 on: March 27, 2008, 08:28:38 PM »
Before you start i suggest that you clean the threads up with a wire brush, 2 on each block and the threads on the eye bolts, spray them with something like WD40.i blocked the car up on the front chassis.
Then jack one side of the spring up and put an axle stand under the spring where the clip is, lower it down and jack the other side up under the spring, undo the eye bolt and drift out, i used a smaller bolt, once its free undo the block then gently lower the spring down to the floor on the jack. do the same with the other side, when re-assembling do one side at a time, use some washing up liquid on the rubbers in the block this will help it slide into the correct position, once you have got the two blocks on tighten them upto the correct torque. then jack the spring up at each end so you can push the eye bolts through, put the nuts on but don't tighten them up. drop the car onto the ground and run back and forth to settle the spring then tighten the eye bolts while the wheels are on the ground. a little bit more advise, you need to get the front wheels tracked up professionally doing it by eye does'nt work, mine was sitting higher than a std spring and was dangerous jumping all over the road, but once it was tracked up using a garage with the right tracking equipment everything was as it should be.
P.S. A little bit of Health and Safety, remember the spring is under pressure. make sure the axel stands and jack are in a position where they are safe and won't slip.
Riding high
« Reply #11 on: March 28, 2008, 11:52:13 AM »
I will hopefully have a go on Sunday if it's not too wet, failing that one evening in the week, with the extra hour of daylight we'll be getting.
I am still struggling to find any garage that will track the car. Everywhere I take it come up with excuses from, 'We dont do old cars' or 'We dont have the manufactures specs for that thing' to 'We don't have the equipment to sort that' or 'we don't do cars that are non standard'. (':x')
It's getting really frustrating, even the guy in the tyre shop yesterday was very reluctant to fit my new tyres to the loose wheels when I told him what they were for. He said it would be dangerous and illegal to fit non standard size tyres to a car and it would bugger the suspension! Honestly (':roll:')
There are only a couple of garages in a 5 mile radius that I haven't tried yet! (':evil:')
Riding high
« Reply #12 on: March 28, 2008, 03:04:24 PM »
dom just dont tell them what its going on!! as for the tracking its easy enough to do yourself to be honest , if its wrong you will know when you drive simply by the feel of the steering . its a simple set up so isnt difficult to adjust .
Riding high
« Reply #13 on: March 28, 2008, 06:48:16 PM »
Well what can i say, its because you live Darn Sarth :lol:  stay away from main dealers and look for a little independant garage or tyre place :) go armed with your workshop manual with all the settings in then theres no excuse.
Riding high
« Reply #14 on: March 28, 2008, 10:18:51 PM »
Few things to add
Torque the leaf spring and top wishbone pivot nuts with the car on the ground.
It will be worth you checking the track rods to make sure that they are not seized, if you are getting the tracking done at a garage they will not be to happy if they are!
I use a gunsons trackrite to do my tracking, well worth getting!
