Author Topic: Riding high  (Read 5292 times)
Riding high
« Reply #15 on: April 01, 2008, 10:52:20 PM »
The while of Egham and Staines wouldn't touch my tracking so i bought a track rite, took 10 mins to do (assuming the track rod bolts can slacken easily) your welcome to borrow it, only trouble is im on holiday from sat until next sat, but its here if you want it
Riding high
« Reply #16 on: April 02, 2008, 09:37:57 AM »
And then I go on Holiday the day you get back!
But that sounds great as I was looking at those Trakrites and they do seem pretty good. The track rod ends do move, but not that freely, so a garage would probably not touch them. I will try and free them up, once I've got the spring back on.
Riding high
« Reply #17 on: April 04, 2008, 10:08:22 AM »
I'm nearly done with the suspension swap, just hit another hurdle when trying to put the new spring on though. One of the bushes in the eye was too long to fit in the stub axle housing, so after trying to ease it in with fairy liquid and then grease, I had to resort to getting the trusty angle grinder out again. I took about 1mm off it, and it still struggled, but I managed to force it, before it got too dark to continue. Not I've just got to put in the new rear shocks on the front, get the wheels tracked and fingers crossed it should be good to go on Saturday.
I definitely think the old shocks were to blame for its ride height, as they were gas shocks, rather than just dampening, they had such pressure that they could easily hold the car up at the front. They were a bitch to take off as I had to really compress them and they kept springing back with such force
Pawel83
Riding high
« Reply #18 on: April 08, 2008, 06:38:29 AM »
Quote from: "Dom"
I don't think the shocks are the problem, probably the leaf spring is just too high. To lower the front suspension you should:
- have as flat leaf spring as possible (it can be even straight, but it's not recommended - the best is 13cm) if it is straight it's good to add one leaf
- you can try the rear shocks, but only if the leaf spring is very low
- the rubber, triangular 'bumpers' should be shortened
- the alloy spring holders can be 11mm shorter (but not necessarily)
There may occur some problems then, eg. the wheels will stand like that /----\, so you will have to adjust it...
(uff - thank god for dictionaries  :lol: )
Riding high
« Reply #19 on: April 08, 2008, 09:49:57 AM »
The spring and all are on now and it seems great. Pretty much neutral camber, just need to get the tracking spot on and its good to go. Also trying to work out the right tyre pressure for my settings. There is pretty much no weight at the front of the car, so I figure I can go pretty flat (early 20s perhaps on the front?)
I am using 145 60 R13s on the front and 155 65 R13s on the rear. Any Ideas on what pressures would be suitable?
My only slight concern is that with using the rear shocks, they are pretty extended most the time, they have around 2" to play with when the car is flat on the ground. The gas shocks I took off are pretty long and are more like pogo sticks than dampeners.
I'll take it for a nice long test drive tonight and go from there.
Pawel83
Riding high
« Reply #20 on: April 08, 2008, 11:04:19 AM »
You can adjust the pressure that way: pump in more air that it is needed - this way the steering wheel will work very easily, but the front of the car can skid while turning with great speed (also the brakes will be worse).  Then keep lowering the pressure until the front stops skidding.
Thats the most simple way:)
