Author Topic: How far have you gone in your 126 Bis?  (Read 4708 times)
« on: July 11, 2007, 12:25:15 PM »
We are planning a trip to kent to see my mum and dad, we live about 160 miles away in Leicestershire, do you think the Bis would make it there and back again?
Also how far have other Bis owners gone with no troubles, any recommendations before we set off?
cheers
« Reply #1 on: July 11, 2007, 04:08:10 PM »
160 miles is that all??
the most ive ever done is 500, over 2 days when going upto Yorkshire, the car was fine, but breakdown cover is essential, spares and tools. (Water & Oil) & fire extinguisher.
some people drive them to Mongolia, on the Mongal rally!!!
Regards
« Reply #2 on: July 11, 2007, 05:15:35 PM »
you will do it no problem just dont go mental and make sure you pack away , oil , spare points and condensor, fuses, some hose repair tape , some electrical wire , electrical tape , and a small tool kit with keys and spanners to fit bits on engine . oh and dont forget some coolant just in case the kettle boils... dont worry if you havent got these bits its just usefull if you have them as a roadside repair kit its an alternative to having to call a recovery vehicle . ciao you are coming down near me arent you ( me sittingbourne) ? if so i will pm my tel no and you can pop in and i might have some old bis bits you can have .  any how dont worry about how far you must drive its how you drive it that makes the problems. :)
« Reply #3 on: July 11, 2007, 07:54:25 PM »
of course u will matey! :wink:
« Reply #4 on: July 11, 2007, 09:02:37 PM »
We were planning to go in the wifes New Beetle but I thought it would be a bit more fun in the Fiat.  Do you recommend stopping or just keep going?  When I bought the car from London I drove it home on a knackered engine so it should be allright with the replacement one!  Also I think the car was sold in Canterbury from new as I have evidence that it was there when I was at college, so it would be nice to take it back!
Thanks for your replies!
« Reply #5 on: July 11, 2007, 09:17:00 PM »
go for it,your car sounds in fine fettle,go easy on it and it will be fine.....im hoping to go to the retro bash with a 2 week old tuned engine to run in!!!.....and its still not done and in!!!!
take it easy and just keep an eye on the temp and listen out for odd sounds,dont be tempted to push on too fast,remember the hare and the tortoise??.......id keep going and just stop for juice etc....
i did the brighton to weymouth run on one aircooled cylinder remember!!!!
have fun and leave the modern at home  :D
« Reply #6 on: July 12, 2007, 04:53:19 PM »
Well I think we are gonna go for it.  Should be fine I mean not much has gone wrong with our Bis -
New engine
New speedo cable
Alternator fell off
New belt
Rocker gasket blew - renewed
So not too many problems - eh?
« Reply #7 on: July 12, 2007, 05:15:06 PM »
go for it mate, so rewarding, break down cover and you'll be fine they are good little engines, they thrive on a long run from time to time.
regards
phreak97
  • Niki!
« Reply #8 on: July 13, 2007, 01:19:10 PM »
i've been two thousand kilometres plus in an air cooled, we had several small (ish) problems, but we did make it in the end.. second try.
we're going to drive it back in a couple of months or so, this time armed with a bit more knowledge.
go for it.
phreak97
« Reply #9 on: July 13, 2007, 07:33:28 PM »
Unfortunatley we will now be going in our New Beetle.  The Bis has started to blow it's Rad fan fuse and I can't work out why.  New two stage fan has been fitted so it's not that, changed relays - not that.  Also dissconnected fast idle sellonoid and it still blows!  Im gutted can't drive to Kent without a reliable cooling fan!
« Reply #10 on: July 13, 2007, 08:23:53 PM »
oh, wat a pooter.........
« Reply #11 on: July 13, 2007, 10:53:25 PM »
take off the door trim /step plate and lift out the rear seat , then unscrew the fixings for the carpet check the wiring loom at the base of the passenger wheel well where it meets the floor water gathers here if the car leaks and deteriates the wiring if not check where the wiring travels under the bench at the filler neck sometimes the seat wears the loom and it shorts out. i have had two cars with problems here
hudsonhenry
    • http://www.retro500.com
« Reply #12 on: July 14, 2007, 05:23:09 PM »
It should be an easy trip, vital to have breakdown cover of the kind that takes your car to where you want not just to the nearest garage for repair.
I have just got back from a 2,500 mile ten day trip around Europe in my 500. A few running repairs were needed including:
New clutch in Italy
Starter motor broken in Italy (replacement broken first turn) had to push started the car single handed for 1500 miles
Bad fuel on the Italian Swiss border so all ignition parts replaced trying to work out the loss of power ( would have smelt the problem with the fuel but I also had the worst cold I've had for years)
Bald front tyres in Paris (too much negative camber)
Drive shaft flexi joint blew up on the way to Calais
And rain, rain rain – except in Italy
In the UK its no problem, you just get relayed back if you break down and cant fix it, I'm never going to complaine about doing a few hendred UK miles in my 500 again
Nigel
« Reply #13 on: July 14, 2007, 05:29:44 PM »
wow good trip nigel,those problems remind me of my WW2 willys jeep trips around europe  :cool:...
« Reply #14 on: July 14, 2007, 09:11:21 PM »
nice i read about the 5oos invasion of europe!!
