Author Topic: How far have you gone in your 126 Bis?  (Read 4709 times)
Tommo32
« Reply #15 on: July 15, 2007, 01:59:51 PM »
some people i know drove to italy in their bis, the two of them and their kid. about 10 yrs ago. crazy.
Idle Steve
    • http://www.mb5.co.uk
« Reply #16 on: July 17, 2007, 11:54:19 PM »
Quote from: "bis13"
take off the door trim /step plate and lift out the rear seat , then unscrew the fixings for the carpet check the wiring loom at the base of the passenger wheel well where it meets the floor water gathers here if the car leaks and deteriates the wiring if not check where the wiring travels under the bench at the filler neck sometimes the seat wears the loom and it shorts out. i have had two cars with problems here
Not far wrong Mick, when I removed the passenger seat belt floor mount to remove the carpet the cooling fan wire had been squashed under the bracket and the cable was flat. Much longer and I reckon mine would have done the same! :???:
The wife calls Him "Cecil"
DaveG
« Reply #17 on: July 25, 2007, 08:53:42 AM »
....managed about 5000 miles last summer, including 22 hours straight to Prague. We ended up somewhere east of Almaty in Kazakhstan. Had very few mechanical problems considering the state of roads, or lack of them...
126s make great rally cars.
