Author Topic: Problem with our POP2000  (Read 7026 times)
kissefa
    • http://www.fiat126.hu
« on: July 10, 2007, 06:32:52 PM »
Hello guys,
I'm writing because I thought you could help us. My boyfriend has a POP2000 and there's something wrong with the engine. Water flows out of it. We have tried to fix it but we didn't succeed :( He (my boyfriend) thinks there is a problem with the coolant pump packing box, but we don't know where to get a new one, or how to get it out of the engine :( Can anybody help us???
Here is the problem somewhere:
And this is the car:
http://autoblog.modulweb.hu/image.php?image=3976&full=1&h=864
« Reply #1 on: July 10, 2007, 06:44:36 PM »
when you say the water just flows out of it do you mean it leaks when you put it back together? if that is the case you need to either make a gasket or seal it with liquid gasket. or is the water going into the oil ?
kissefa
« Reply #2 on: July 10, 2007, 06:48:50 PM »
I think both :(
« Reply #3 on: July 10, 2007, 06:49:54 PM »
if water and oil are mixing you need to replace the head gasket  :cry:
kissefa
« Reply #4 on: July 10, 2007, 06:55:16 PM »
We've tried another coolant pump too. But it wasn't better either. Last summer the cylinder head went wrong :( And the car isn't working for a year now :(
And we wanted to take it to our big summer meeting...
« Reply #5 on: July 10, 2007, 07:11:35 PM »
did you get the head skimmed to make it flat again??....its hard to give a clear answer without seeing the car,but it could well be the head gasket again....
kissefa
« Reply #6 on: July 10, 2007, 07:31:45 PM »
well, it's a bit complicated. The head of the original engine went wrong, so it was replced with another engine (from another car) but the problem remains the same, that is, water is keaking from the coolant pump. The problem is, that we don't know whether the water can mix with the oil, so we did't even try to start the engine. The other problem with the original engine was that the cooling fan didn't start.
« Reply #7 on: July 10, 2007, 07:40:42 PM »
ah,you need to hear from the many bis experts/fans on here,i only had one for a short time.....you will im sure get some help
kissefa
« Reply #8 on: July 10, 2007, 07:44:43 PM »
That would be great, because we're hopeless :(
Paul Clough
« Reply #9 on: July 10, 2007, 08:58:34 PM »
I have a few questions that may enable me to help...
What makes you think that water is mixing with the oil?
When you look at the back of the car which side does the water leak from?
Is it a gush, flow, trickle or spots?
When you say "coolant pump packing box" do you mean the pump cover?
Paul
Its a What?
« Reply #10 on: July 11, 2007, 07:27:18 AM »
it sounds like the thermostat housing is not watertight just needs sealing as thats the only place it can leak. if its going into the engine oil its possible that the seal behind the pump has failed and so the two are mixing , but kissefa states that its gushing out so it must be a simple leak . have you looked at the hoses are they intact and tight ? its hard to give advice with a description that says so little.
kissefa
« Reply #11 on: July 11, 2007, 08:35:44 AM »
Quote from: "Paul Clough"
Paul
1. We don't know whether it's mixing or not.
2. From the left.
3. Trickle.
4. No, I mean the thing that you can see in the drawing
« Reply #12 on: July 11, 2007, 09:59:52 AM »
Sounds lik 'stat cover to me as Bis13 says.  If fan dosn't work cheak fuse, it proberbly needs a new two stage switch, You can get these off Ebad.
Paul Clough
« Reply #13 on: July 11, 2007, 03:28:42 PM »
Yes I think I agree... However the water pump has a cover, to which the thermostat is connected!! nightmare...
Best fix in to buy new water pump gasket and thermostat gasket. Remove both bits, clean up thoroughly... look for uneveness on all mating surfaces, these tend to corrode.
If you see any uneveness you need to replace that part too.... I just bought a new thermostat from specialist.. cost about £28.00.
Once youre sure the mating surfaces are sound use a decent gasket glue and apply to both gasket and surfaces... follow manufacturers instruction here...
Once put back together you should be OK!!
The fan not cutting in could be because the engine doesnt get hot enough!! In this case the thermostat definatly needs replacing...
Let us know how you get on'
Paul
Its a What?
« Reply #14 on: July 11, 2007, 06:19:08 PM »
is it leaking from point a  b  or  c ( c is the paper with no c! ). if b is leaking you need to make a gasket like in the photo, if from a the same applies if from c then there is a seal failiure and needs peplacing.
point c is found under the sump .
