Author Topic: Problem with our POP2000  (Read 7026 times)
kissefa
    • http://www.fiat126.hu
« Reply #15 on: July 12, 2007, 09:59:33 AM »
Quote from: "bis13"
is it leaking from point a  b  or  c ( c is the paper with no c! ). if b is leaking you need to make a gasket like in the photo, if from a the same applies if from c then there is a seal failiure and needs peplacing.
point c is found under the sump .
It's point C where the water comes from. Which seal sould be replaced then?
Paul Clough
« Reply #16 on: July 12, 2007, 03:21:08 PM »
:cry:
Ouch!!! point "c" would suggest that a new water pump is needed....
you might as well replace all the gaskets too!!
paul
Its a What?
« Reply #17 on: July 12, 2007, 03:34:59 PM »
if its point c i do believe there is a seal there but it would be best to replace the lot . if you have a spare engine just drain the oil and remove the whole sump and replace it with the sump from the spare . that is of course if you cannot get the part in time before you need to go to your meet. good luck with fixing your car , let us know how it goes . mick
kissefa
« Reply #18 on: July 12, 2007, 07:17:32 PM »
Quote from: "Paul Clough"
:cry:
paul
It's nearly impossible to find a new water pump here in Hungary :(
kissefa
« Reply #19 on: July 12, 2007, 07:18:26 PM »
Quote from: "bis13"
We've tried replacing it from the other engine, but the problem is the same.
« Reply #20 on: July 12, 2007, 07:32:41 PM »
Can you post a photo?
« Reply #21 on: July 12, 2007, 07:37:17 PM »
thats strange as i have never heard of this problem arrising before . are you quite sure that the water/coolant is coming from here? do you actually see it coming out? i have a whole sump here with a good pump that i dont want ! but it will cost too much to send to you ! well it looks like you need to get the pump out to asssess what has failed and they can be a right pain to get out as its been getting hot and coupled with water/coolant corrode , i suggest you use the sump you have out of the car remove the body with the filter on it (two bolts) to reveal the lower part of the shaft clamp this and be carefull not to damage splines then if you cannot get the pump undone with a hex key use a small cold chisel to turn the hex bolt then if the pump is okay replace the seal . have fun and if you find it hard going take five minutes have a cup of tea and start again , all the best mick
« Reply #22 on: July 12, 2007, 08:48:17 PM »
or just go a/c and sleep well
