Author Topic: Mucky oil in radiator .  (Read 7927 times)
jpimpao
« on: June 17, 2007, 10:05:07 PM »
Just came back from a nice trip and noticed mucky white oil, looks like grease just on top of the water radiator tank. The engine oil in clean, no water and did notice also that some water from radiator tank did came out trough the cap,probably to much pressure.
The car had a new head gasket fitted 1500 miles ago, according to the seller and I was wonderig if this mucky oil could be from not having flush the water hoses propely after the head gasket blew off.
I always top up the radiator until the water comes up the tank pipe.
Does the water tankhas a hose breather.
The engine temperature was alright, sometimes went up a bit but never on red, would go up /// before red.
I would appreciate some help, please.
Jorge
« Reply #1 on: June 17, 2007, 10:27:10 PM »
hi Jorge, when you top of with water you should bleed the coolant system everytime. to remeove any airlocks. this is a little red pipe at the front of the car by the heater matrix. run the car after filly up and open this screw catch the water in a cup this will allow the air in the system to escape.
Was there alot of white muck? it shouldnt really get near to the red on the temp gauge should never go past just over half way.
see how it goes, at the worst its only a new head gasket.
regards
Wozza
« Reply #2 on: June 17, 2007, 10:40:00 PM »
If it is sitting next to the filler neck of the tank and it is actually powdery to the touch then it's likely to be harmless deposits from the antifreeze boiling up or leaking out under pressure mate. if there is a slight leak anywhere then the escaping mixture will dry to form white crystals. if its somewhere else on the tank, and is greasy to the touch then it might be some form of rustproofing jelly. check to see if you can scrape a little more off from above it. I cant think of anything else that ought to be on or around your expansion tank mate. P.S. try to get hold of a Hygrometer from somewhere to test the strength of your antifreeze mixture. because if that is very weak and you get no high temp. readings then your temp. sender might be faulty.It should have a 50/50 mix of neat antifreeze and water.
jpimpao
« Reply #3 on: June 17, 2007, 11:11:30 PM »
The mucky staff is white and took it out with my finger and feels like grease just sitting around the filler neck tank, the engine oil is clean, I tought that if the head gasket has been blown I would have water in the engine oil not another way around, am I right. I did play around with the heater a bit during my trip turning it on to hot air and the engine temperature came down, probably because the water circulated all the sistem, I really don`t know.
Do you think it will be a good option to by a product to clean the radiator , what do I have to do to flush all water, is it from the bottom of the radiator.
I never had any water leaking from the water tank.
There is no smoke out of the engine.
help from you all is much appreciated.
Thanks again for your time.
Jorge
« Reply #4 on: June 17, 2007, 11:50:19 PM »
im sure its all ok Jorge, iv had milky deposits before and that was due to condensation, however that wa sin the oil filler neck. There is a large pipe/tube/hose that goes onto the thermostat housing/waterpump if you take that off all the water will drain out.
then fill the tank bk up with water put the hose back on, run the engine, bleed the coolant (at the front of the car as i descibed earlier)
then drain water, do this a couple of times to flush it through.
It is possible to get oil in the water if headgasket has blown. (depends where the gasket has split)
regards
jpimpao
« Reply #5 on: June 18, 2007, 12:42:17 AM »
Thanks very much Chris.
Jorge
jpimpao
« Reply #6 on: June 18, 2007, 12:51:48 AM »
Chris,
You mencioned to drain the water a couple of times to flush it through, do you meant to take the hose pipe from the thermostat housing, drain, fill up the water tank with water and bleed the coolant, to do this process 2 times, it that right.
Thanks Mate
Jorge
« Reply #7 on: June 18, 2007, 10:50:31 AM »
there are cooling systems flush additives if you want to do a good job!
Bars and Wynns make them, one on ebay at the moment
http://cgi.ebay.co.uk/BARS-FLUSH-COOLING-SYS-CLEANER-REMOVES-LIMESCALE-RUST_W0QQitemZ320127169004QQihZ011QQcategoryZ72205QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
« Reply #8 on: June 18, 2007, 07:39:47 PM »
Quote from: "Chris Lakin"
regards
Hi  My temp guage allways gets near the red so I have to cool it with my override switch,  I have put a new two stage switch in so what could be the problem?
Idle Steve
    • http://www.mb5.co.uk
« Reply #9 on: June 18, 2007, 09:50:50 PM »
One thing not to do is over fill the header tank with water. There has to be room for the water to expand as the engine gets hot. If no space is left, the water expands and has no where to go and the cooling system reaches the max allowed pressure of 0.98 bar and then lets the water dribble out of the filler cap. :cry:
When you have drained out the water turn on the ignition and you should see a red light on on the dash (top right light picture of a radiator with a cross, this should light when the water is drained) When you re-fill the system fill it so that the light just goes out. It will keep coming on as the air locks go away, just keep topping it up.
My level is just set so that it just comes on under heavy braking (proves it still works)
If too much is in just syphon some out.
Since doing this the excesive pressure that I had in the rad hoses (which I thought was a blowing head gasket) has now gone as the coolant can expand into the air gap. :D
The wife calls Him "Cecil"
jpimpao
« Reply #10 on: June 18, 2007, 10:41:17 PM »
Hi Steve,
For what I understand  and if I am correct, you just fill the radiator with enough water and stop adding just when the red lights goes out and keep topping it up if the red light comes on again , is that right. I always had filled up the water tank right to the top.
Jorge
Idle Steve
« Reply #11 on: June 18, 2007, 11:07:26 PM »
Yep, thats right. once you get the level correct you will then know instantly if you start loosing water for any reason.
banjomandolin
2 Stage sensor.
« Reply #12 on: June 18, 2007, 11:08:04 PM »
Ciaoflyer. You have to carry out the saucepan test on your rad sensor which will prove whether or not your sensor is working. To do the test you need a test meter with a "continuity" facility. If you tell me you have one I will advise which wires to connect. You must also be prepared for "I hope you aren't contaminating my saucepan with your oily engine thingys". Best to do it while she's at Tesco.
John Clark
Idle Steve
« Reply #13 on: June 18, 2007, 11:13:18 PM »
Or at Bingo! she'll be there longer. Better still hair salon, 3 Hrs & 50 bloody quid. Remind her of that when you want another Rad fan switch! :D
jpimpao
« Reply #14 on: June 19, 2007, 12:20:19 AM »
Thank you very much for all your help.
Jorge
