Author Topic: Mucky oil in radiator .  (Read 7927 times)
Re: 2 Stage sensor.
« Reply #15 on: June 19, 2007, 07:55:30 PM »
Quote from: "banjomandolin"
Ciaoflyer. You have to carry out the saucepan test on your rad sensor which will prove whether or not your sensor is working. To do the test you need a test meter with a "continuity" facility. If you tell me you have one I will advise which wires to connect. You must also be prepared for "I hope you aren't contaminating my saucepan with your oily engine thingys". Best to do it while she's at Tesco.
We will have to get together so you can take a look!
« Reply #16 on: June 20, 2007, 10:44:29 AM »
Either my temp gauge lies or something but my temp never venture up to near the red.
The fan comes on a bit every so often.
I run 100% coolant just because I bought some coolant, started filling it to find it sortof filled-up...
I wasn't thinking to work-out how much it would need and just left it like that. Bled the system and all seemed well.
Timing can also make an engine run hotter.
« Reply #17 on: June 20, 2007, 04:50:15 PM »
thats what i did get the best coolant your pockets will allow and chuck it in with no water saves alot of agro.
Idle Steve
    • http://www.mb5.co.uk
« Reply #18 on: June 20, 2007, 05:48:34 PM »
Just browsing the net and come across this quote "Antifreeze, little know fact, neat antifreeze will freeze at -6°c, that's all, its not until you mix it with water that the freezing point lowers."  Dont know how true this is but it makes you think. :???:
This is the link where I found it, http://www.brick-yard.co.uk/misc/snow/winterprep.htm
The wife calls Him "Cecil"
« Reply #19 on: June 20, 2007, 11:29:06 PM »
I still recon you get 100% lubrication in the whole cooling system.
100% lubrication = no corosion?
And I recon the density has a little to help as the denser coolant should take heat from the engine and transmit it through the radiator better.
I dunno but whatever the theory is, 100% coolant is what my BIS seems to run very well on.
Can't see me changing as I figure it ain't broke so I ain't fixing it.. :cool:
« Reply #20 on: June 21, 2007, 05:32:58 PM »
well if you buy the proper high quality antifreeze they quote not to mix with water in colder climates , i used to have three types of coolant that i put into our wagons from arctic to tropical  and have never used water .  as for adding water makes the freezing point lower thats complete rubbish as if that was the case manufacturers would supply watered down coolant and state to use as 100% coolant which would cost less to produce and the same for us to purchase dont you think?
« Reply #21 on: June 30, 2007, 06:03:14 PM »
My cooling fan comes on when the at this point - (red mark)
and then it cools to about halfway, is this correct?
jpimpao
« Reply #22 on: June 30, 2007, 06:28:07 PM »
My car goes up that red mark to .
Jorge
jpimpao
« Reply #23 on: July 05, 2007, 01:02:30 AM »
Hi again,
I did empty and flush the radiator, filled up with clean water and added radiator cleaner,  the engine runned  for 30 minutes, again drained the radiator and flushed a couple of times, I coud see the red light indicating that the radiator was empty. Try to fill up with new coolant but only took 2 litres of it, started the engine and I could see the water just coming out of the water  tank, the manual says that will take 4.8 litres  am I missing something.
I would appreciate your help, please.
Thank
Jorge
Paul Clough
« Reply #24 on: July 05, 2007, 07:27:04 AM »
:D
There is a bleed screw in the front luggage compartment in a bis.... Right in front of the steering wheel.... sat on top of a black plastic box,  It is screwed down with a small cross drive screw but you should release it, then lift the tube upright (looks like screen wash hose) and undo the screw at the end of the hose........ run the engine warm and wait until all the bubbles have gone..
This should be done with the heater in the hot position too.
hope that helps..
Paul
Its a What?
