thanks everyone for all your help with things so far, but i am now sure this is an electrical fault.
the supply lead to the coil pack is not going live, my guess is that there was a poor conection some where or a fracture allowing arcing, but now there is nothing, the fualt is definately before the fuse box somewhere,
i have been looking at the buse box and it appears to be that the orange coil-pack feed (it is blue in the engine bay but is orange just before it passes through the bodywork under the rear seat.) is not going live.
the orange wire is feed via the indicater fuse.
i think that there is something wrong with the power to the indicaters too as the flash is weak and slow.
i have not checked the rear screen heater operation as it will drain the battery too quickly if it is working ( i assume it is not as all three things Indicaters, Coil-pack feed and Rear screen heater are all interconected)
Can one of you clever electical wizzards please help me out here as i am out of my depth when it comes to electrical things like this.
maby an ellectrical diagram would be helpful or if you can tell which wire to check ( there must be common supply feed to these items but i dont know which it is)
please please help me.
p.s. just to allay any fears that i may have missed something simpler,
i have checked the coil pack, plugs, HT leads, condener, and points on my other Bis and all are working well. i have also run a new wire direct from the fuse to the coil-pack to illiminate the possibility that the orange wire is fractured.
