Author Topic: possible piston ring failure  (Read 12395 times)
Idle Steve
    • http://www.mb5.co.uk
« Reply #15 on: June 02, 2007, 10:57:30 PM »
Sorry, just read your post again, are you saying that the fuse is not coming live when the ignition is turned on?
The wife calls Him "Cecil"
Idle Steve
« Reply #16 on: June 02, 2007, 11:21:34 PM »
Me again, :D
According to the manual it states "The following circuits are not protected: Ignition, Starting and low oil pressure warning light"
That means that the ignition must be a direct feed from the ignition switch and does not go via a fuse. Try looking and testing around the steering column, maybe the ignition switch is faulty? :???:
The fuse you are looking at only does the heated rear window and it's warning lamp and will be dead because I'm sure the relay only operates when the alternator is charging (engine running) so it cannot be left on without the engine running.
If you have no luck I will trace my feed for you and see where it is fed from. (I assume you have a Bis?)
PS here is a link to a online manual but the site is down at the moment :cry:  http://www.fiat126.hu/book.php?book=15
Steve.
neil 126
« Reply #17 on: June 02, 2007, 11:25:01 PM »
hi steve thanks but no the engine did not fire up, stil no spark.
there must be some power but not enough to induce a good electromagnetic collapse in the coil, this is my thnking behind the por operation of the indicators.
hi pedro what is this ignition ballest resistor. i do know of a it located behind the spare wheel but what does it do and how does it work?
learnt it the hard way
neil 126
« Reply #18 on: June 02, 2007, 11:52:02 PM »
hi steve i think when it saiys thet the ignition is "unprotected" it mea ns that the starter motor is unprotected as this reqires a lot of power to operate, therefore it is feed direct from the battery, and not via the fuse box.
The engine does turn over quickly when the ignision key is turned.
the wire that is not going live (the orange one at the fse box/blue at the ignition coil) should be live in order to power up the primary coil in the coil pack, the primary coil is collapsed when the points are seperated thus inducing a high voltage pulse to HT leads.
thanks neil.
« Reply #19 on: June 03, 2007, 01:43:06 AM »
Hi Neil
Ballast Resistor: is a resistor that is switched in and out of the 12 volt supply voltage to the ignition coil.  check the connections as this is the supply to the coil, The ballast resistor lowers voltage after the engine is started to reduce wear on ignition components. It also makes the engine much easier to start by effectively doubling the voltage provided to the ignition coil when the engine is being cranked. in the olden days they used a lower voltage coil 6v 9v when the resister is cold it passes 12v as it warms up it goes high resistance and brings the voltage down to 6v 9v or what the working parameters are, if you have a meter you can measure the voltage to rule another thing out of the loop.
« Reply #20 on: June 03, 2007, 07:39:00 AM »
this fault that you have is exactly as i have had recently where the orange meets the blue there is a slide connector in a little plastic clip box make sure they are connected as i found mine were just laying on top of eachother!
Idle Steve
« Reply #21 on: June 03, 2007, 08:17:10 AM »
The 126 Bis does not have a fancy heated rear window which only comes live when the engine is running.
You are quite right about the orange wire at the fuse box as I have been following the wiring diagram.
There is a light blue wire which runs from the ignition switch to the back of the fuse box on fuse No 4 which is the indicators and then loops to fuse N0 2 which is the HRW.
From this loop is the orange wire that you are talking about.
If these fuses are dead with the ignition on then the fault has to lie between the ignition switch and the fusebox
Does the alternator light work as this is fed off the same circuit with a light blue wire from the rear of the ignition switch?
The ignition circuit has no fuse whatsoever as it is on the primary side of the 2 fuses which only affect the indicators and HRW, ie you will find when your problem is solved you can remove every fuse in the fuse box and the engine will still run!!!!!
Not good as any fault on the ignition could set fire to your car! (don't want to put you off, this was done a lot on older cars.
Link to ignition diagram & key:
http://www.fiat126.hu/books/15/141.gif?PHPSESSID=1906b3d53d350ca7af61fee075c0e1c1
http://www.fiat126.hu/books/15/147.gif?PHPSESSID=1906b3d53d350ca7af61fee075c0e1c1
http://www.fiat126.hu/books/15/138.gif?PHPSESSID=1906b3d53d350ca7af61fee075c0e1c1
Check out the diagrams and see for yourself,
Steve.
Idle Steve
« Reply #22 on: June 03, 2007, 01:53:35 PM »
Quote from: "pedro126"
Hi Neil
What a cracking explanation of a ballast resistor!
The resistor by the spare wheel is actualy the dim dip resistor (somthing that was fitted to cars around that time which turned the headlights on at half brightness when the ignition was on and the switch in the sidelight postion) This was to stop people driving at night with only the sidelights on.
If you turn on the ignition, put the sidelights on you can feel the resistor warm up (Dont stick your finger in like I did, it hurts :oops: ) You will notice that the headlights are on dim.
The coil on the Bis is 12volt and does not use a ballast resistor, so the voltage at the coil should be 12v.
One less thing to worry about Neil!
Steve.
« Reply #23 on: June 03, 2007, 07:26:38 PM »
Hi Steve, totally confused me now (which does'nt take alot) in the manual it say it has a resistive wire
and also on a previous string
http://www.fiat126club.co.uk/forum/viewtopic.php?p=3204&sid=d7e47223e2d7011fa7dafd3616515cdd
Idle Steve
« Reply #24 on: June 03, 2007, 08:54:48 PM »
Bugger, you have got me bang to rights, the diagram I have shows no resistive wire where as yours does?
Just been out to the car and checked the live feed to the coil with the ignition on and I have 6volts (DoH!) but the ballast resistor must be part of the wire as it is not the resistor by the spare tyre.
Have you checked the wire from the ignition swith yet?
Try running a wire from the battery positive to the dead fuse and see if she will start? If she does then the fault must be between the fuse box and the ignition switch!
Steve.
neil 126
just a quick update
« Reply #25 on: June 03, 2007, 11:02:12 PM »
well i'm sure it won't be long now, but there is yet another obstacle in my path to nirvana.
there was a loose conection bethind the hot air fan at the bulkhead, the indicators are on and i am getting a good spark at the plugs but the bloody thing will not start.
i have checked the pistons for movement, ( you can tell i am getting desperate) and they rise and fall as they should, i have checked the valves previously but i think that there must be something wrong here. maby the pushrod has got stuck or bent. or maby the rocker/tapetts mounting is loose and not giving proper movement to the valves.
does anyone else have eny other ideas?
this is turning out to be a real test, not just of my mechanical/electrical knowledge but of my patience also.
p.s. the current symptoms are this.
the engine turns over quickly, there is good spark from the plugs,the pistons are moving, there is petrol going into the inlet manifold and thus to the cylinders, but there is no explosion. not even a puff.
i will try turning over agian tomorow morning just in case it is flooded, but i am not holding my breath.
thanks neil.
« Reply #26 on: June 03, 2007, 11:26:12 PM »
it sounds like the timing is simply out get someone to crank the engine over and move the dizzy till it fires up, make sure you have made a mark on the dizzy and base to realign if not successfull. another thing is get some easy start and give that a go.
Idle Steve
« Reply #27 on: June 04, 2007, 07:00:33 AM »
Have you just bought this car and never had it running properly or has it been fine up untill this fault?
Did it slowly get worse or happen instantly.
I had the starting problem once after checking the timing, good spark but would not fire. It had driven 110 miles the day before perfect, left it till the following day still nothing. Went back to the dizzy wobbled all the wires etc then started first time (never did find the problem all connections were fine and a big blue spark, it's been fine 300 miles later). Fiats!!!!!
Steve.
« Reply #28 on: June 04, 2007, 09:39:47 AM »
the sort of agro neil is getting sounds very similar to what i am getting right now with my polski, i have spark, fuel, and everything seems okay but to start the car is a bitch. however if i spray a bit of easy start into the intake it fires up no problem , and afterwards when i start the car it fires up ok. its only the first starting .
Idle Steve
« Reply #29 on: June 04, 2007, 01:03:32 PM »
Neil, you can check the timing static by removing the plugs and re-connecting the leads, place the plugs on top of the engine.
Remove the dizzy cap. Look for the little notch on the crankshaft pulley and mark it with some tippex if it's not been done already.
Turn the engine round clockwise untill the pulley mark is about 2" from the timing marks by the top of the pulley (I use a screwdriver and gently turn the alternator fan blades to do this.)
Turn on the ignition, turn the pulley slowly, the points should open and the plugs spark when the notch on the pulley is at the first mark of the pointers (this is 10 deg. before TDC)
If not adjust the dizzy either way and re-check untill spot on.
(you may have done this already if so ignore this, it may be of some use to someone else.)
Have fun, keep us posted! :D
