Author Topic: Tachos and other gauges  (Read 9837 times)
Marek
« on: January 28, 2007, 09:23:49 AM »
Heya,
curious to know if anyone has any thoughts on setting up a tacho, i'd love to know what revs the car is doing.
since the stock gearbox doesn't have a tacho, we need to come up with some other solution, only thing i can think of is by taping into the distributor and doing some crazy electric circuit board tricks..
another idea, what other gearboxes bolt onto the 126 that has a tacho?
looking forward to some interesting responses.
1990 Nissan 180sx sr20det - 250hp
1990 FSM Niki aircooled 650cc - 25hp
« Reply #1 on: January 28, 2007, 09:40:29 AM »
hi Marek,there are various ways off doing it,i used a harley davidson sportster rev counter,(thanks nigel) its used to low power and vibration  :lol: ,off ebay,works a treat wired into the coil and power.
red lines at 6k ish rpm as well,tho i try to keep mine down to 5k.
check out the garage pics and you can see where i mounted it on the dash board.
i also fitted a live oil pressure gauge,i use a smiths one,again from ebay,the oil pipe just connects to the pressure sender in the block,flexi pipe from a boat fitters/chandlers connects the lot together,i prefer live to electric sender,more accurate.
thats it in my cockpit, apart from the switch for the rear deck and the warning/reminder light for the fuel pump
hope this helps  :D
Marek
« Reply #2 on: January 29, 2007, 01:48:41 AM »
that's brilliant, i am on ebay now hunting one down haha
i'll make sure i take photos and document the process
thanks heaps,
Marek.
Re: Tachos and other gauges
« Reply #3 on: February 23, 2010, 11:02:13 AM »
I've just bought this
http://cgi.ebay.co.uk/harley-davidson-rev-counter-tachometer-dyna_W0QQitemZ260551281488QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item3caa110b50#ht_500wt_924
In the hope that i could wire it into my 500. Not seen one before, so bought it out of curiosity as much as anything else. Anyway, I should have done some more research into whether or not it could be made compatible.
I was hoping i would find some wires out the back that i could cut and splice to fit into the circuit - instead however there is just a 6 pin scart like socket and nothing else :-(
I have spent all morning looking for a suitable connector/wiring harness/adapter/anything! to no avail!
Should i just put it back up for sale?
Rear view
RSPSTEVE
« Reply #5 on: February 23, 2010, 12:10:56 PM »
I think that is just the speedo drive.
The Harley Rev Counter/Tacho is electrical, so I was hoping it would work off the coil, however I was expecting wires out the back and not a socket
« Reply #6 on: February 23, 2010, 12:33:11 PM »
I've just found these images on a Harley forum
http://linson.us/harleydavidson/sportsters/bertshowto/berts_how_tos__tachometer_instal.htm
This is the exact Rev counter i have. Where can i get the connector/wires pictured?
I would ask on the forum, but it was posted in 2003!
Eklipze3k
« Reply #7 on: February 23, 2010, 01:23:08 PM »
Based on that guide, it an original Harley accessory so I would imagine they would carry spares. Try contacting HD-UK or your local HD dealer - http://www.harley-davidson.com/wcm/Content/Pages/Utility/hd_contact_us.jsp?locale=en_GB&bmLocale=en_GB
Re: Tacos and other gauges
« Reply #8 on: February 23, 2010, 01:26:35 PM »
 Or you could try American eBay.
tiny126
« Reply #9 on: February 24, 2010, 06:36:13 AM »
How about a standard off the shelf aftermarket tacho. I have a brand new one in my loft that I bought about 7 years ago when I was into mk1 MR2's but never fitted. It has a change light and you can also change the background light colour. You just wire it to the coil and power supply (I fink). The make is auto tech or something. I bought it from Halfords and it was only £50 ish. I willl check the make and model if you are interested.
bobblehead
  • monkeys on the move ..
    • my fiAT 126 PICK UP
« Reply #10 on: February 24, 2010, 07:12:49 AM »
i fitted a rev counter on my mini simple as .... just fed a lead to the coil and i think another to a earth and that was it?
i think ??? was when i was 17 .... along time ago ? ...
anyway trust me , was 2 wires and no hassle
Eklipze3k
« Reply #11 on: February 24, 2010, 10:43:18 AM »
The problem with the ones from Halfords (IIRC) is that they won't work on anything smaller than 4-cyl
« Reply #12 on: February 24, 2010, 11:36:10 AM »
If you know a little about electronics and can use a soldering iron Velleman do a digital tacho kit No K2625 and can be used on 2-4-6-8- cylinder engines.
http://www.esr.co.uk/velleman/k2625.htm
« Reply #13 on: February 24, 2010, 12:52:08 PM »
Electronic Gizmos  ::)
I guess it would make no difference if you were running a standard or twin spark coil set up  ???
tiny126
« Reply #14 on: March 03, 2010, 10:37:28 PM »
Thanks Eklipze3k, Saves me trying to fit it.
Rob
