Hallo to everybody.
Everything is interesting. Maybe I'll be wrong but I' like to say something.
According me, better to use an electronic tacho, simpler and cheaper.
There are universal tacho that have a switch to select cilynders number.
Once upon a time there was a led tacho building kit made for 126. Very cheap, maybe 5 pounds. I'mnot able to find anymore.
The site should be this:
http://xlabs.pl/If somebody finds new... make us know.
I don't know about jaycar kit but in confront of vellman one has more numbers on display:
http://www.jaycarelectronics.co.uk/productView.asp?ID=KC5290&CATID=25&form=CAT&SUBCATID=347I don't think that wasted spark mode is a problem because the coil is always one so the number of ignitions too but it happens on 2 cylinders meantime.
Once upon a time tacho gauges were sold here too:
http://www.autoquariat.at/englisch/spare/stpu.htmI think that can be used tacho from 2 cylinders 4 stroke motorbikes(as you already do) but from 1 cylinder 2 stroke as for exemple one made for vespa that doesn't reach high rpm so it will more accurate.
If you know what to change you can use tacho from 4 cylinders:
http://fiat126.hu/?p=79&a=147The problem could be that the tacho can work fine with your ignition,I can't add something more but an exemple only:
http://www.ovingtonpaint.com/fiat/id5.htmlI hope to learn something more.
Thanks a lot.
Good bye
