Author Topic: how do i convert to unleaded  (Read 8575 times)
126fan
« on: September 21, 2006, 09:36:13 PM »
hi
ive just got a 1979 deville and have found it runs on leaded fuel how do i get it converted whats involved and whats likely to be the cost?
i know i can use and additive but id like it be unleaded as knowing my lick ill forget to put the additive in!!!!
thanks in advance
mikee
« Reply #1 on: September 21, 2006, 10:23:51 PM »
Check out this site www.leadedpetrol.co.uk You can still buy leaded petrol, i have two garages near me in warwickshire, so the chances are there will be one near you. If you can't find a local garage on their web site, try e-mailing them as it seems not all garages are listed.
With the additive if you forgot to put some in on the odd occasion, i don't see that it would do that much harm, as the engine will probably have a build up of lead inside already. This does not mean that you can disregard the need for an additive though.
Regards
Mike
« Reply #2 on: September 21, 2006, 11:29:44 PM »
firstly unless u rag your car like hell those valves arnt going to break, it will take many thousands of miles before they do! Secondly adding a drop off additive will sort it, i bought this tonight off ebay
http://cgi.ebay.co.uk/Castrol-Valvemaster-Lead-Replacement-for-Stag-VW-Austin_W0QQitemZ160032867935QQihZ006QQcategoryZ72205QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
my early white aircooled has 97k on the clock, the old guy before me had a few tank conversion which houses a lead/catalyst which goes into the fuel and thus lubes the valves. very clever!
the bis's valves aree strong enough to take unleaded, they never suffer from worn valves. I cant see the aircooled being much different.
regards
fiatfsm
« Reply #3 on: September 22, 2006, 08:37:10 AM »
chris, those catalysts dont work, they are a con.
« Reply #4 on: September 22, 2006, 09:52:07 AM »
I will second that the lead catalysts dont work! Loads of independent tests done on them and the conclusion was that they are a waste of time and dont do a thing.
darrel
« Reply #5 on: October 02, 2006, 01:01:36 PM »
Its strange because on my Skoda's the Powerplus definately works. They are great at increasing the octane rating back again. I just set the timing/carb to 4 star leaded settings and put 95 ron in with the powerplus which stops the pinking.
« Reply #6 on: October 02, 2006, 01:41:19 PM »
hi darrel ive heard more people now say they are a waste of time than i have people endorsing them  :???: which is ashame because i loved the idea they were given to the russians to use in our loaned hurricanes during ww2 because of their poor fuel queslity.  ive even spoken to one person they said its dissintergrated in the taank  :???: which is a bit worrying.  Yours is valled powerplus? soundsmore like an additive?
regards
darrel
« Reply #7 on: October 02, 2006, 02:20:56 PM »
Ah no, this is an inline catalyst that you have to get the right one for the engine. Not those rubbish lead balls you put in the tank. These are tin I think. Something about a chemical reaction to the petrol???I cant remember exactly but they are not cheap (£80 +) But bearing in mind our Skoda's were made in CZ they were not the greatest quality valve guides. As such if you dont run one of these the engine smokes within 6 months. Ive run one of these for 3 years, 25000 miles and have not noticed any increased wear rates.
phreak97
  • Niki!
« Reply #8 on: July 16, 2007, 03:23:34 PM »
theres 126s which are made to run unleaded petrol, australia got them as the fsm niki (im australian). so find out what makes them run unleaded, and buy that bit:P i thought cars with an alloy head could run unleaded, but i dont know if this is true, is that right? i know nikis have an alloy head.
phreak97
James
« Reply #9 on: July 16, 2007, 10:26:25 PM »
whats the deal with the bis and lead/unlead?
« Reply #10 on: July 17, 2007, 07:44:43 AM »
no its all to do with harder valves .
« Reply #11 on: July 17, 2007, 07:53:18 AM »
i think he means alloy heads have valve seats fitted,and hopefully thy are hard enough,as opposed to just being cut into the iron head,i doubt the nikkis were any dif to the normal cars,and cannot use unleaded indefintly,but with 126 life projected at maybe 30-40 k miles of light driving they thought they could get away with it.........all you need to do is get hardened valve seats fitted...........while your doing it go for bigger valves and a cam etc......
phreak97
  • Niki!
« Reply #12 on: July 17, 2007, 12:46:27 PM »
concidering post 1980 cars here are meant to run unleaded, and seeing the niki was released in 89, id be fairly suprised if they only ran leaded.
just did a google search and apparently australian regulations required them to run unleaded, however my only source for this information is another forum post somewhere else.
phreak97
« Reply #13 on: July 17, 2007, 03:19:50 PM »
do yourself a favour and run with a fuel additive or have it converted or it will all end in tears .
phreak97
  • Niki!
« Reply #14 on: July 18, 2007, 02:15:01 AM »
lol.. i might, since i already put it in every other car i have.. i was kinda hoping i wouldnt have to though:(
phreak97
