Author Topic: how do i convert to unleaded  (Read 8575 times)
« Reply #15 on: July 18, 2007, 11:28:31 AM »
if your just poodilng around dont bother,i dont in my standard 650.i only use it for octane boost in my tuned motor,i use castrol valve master plus,i can run more advance with it........ :cool:
the normal engine just uses the cheapest unleaded,if or when it starts loosing power with eroded valve seats etc i'll chuck anothe head on......
(i wouldnt do that with a bis tho,too much hassle doin a head on them....)
Maddog
« Reply #16 on: July 24, 2007, 01:44:32 AM »
all cars with an alloy head have hardened valve seats, this includes the 126, non hardened steel seats would wear out in a few thousand miles no matter how much lead you put in your petrol
  cast iron heads don't have hardened seats because cast iron is much harder than steel and a thin coating of lead is enough to protect them,
 all valves are hardened,
 if your car suffers pinking on standard unleaded then use super or get the timing retarded slightly.
 according to its previous owner, my 126 has been run on unleaded since they phased out leaded about 22K of its 25K and  runs perfectly,
phreak97
  • Niki!
« Reply #17 on: August 16, 2007, 09:48:56 AM »
aswel as the regulation thing, nikis all have a sticker under the fuel cap which says "UNLEADED FUEL".. or at least they have some brown cap where the sticker used to be, it had to look at two different cars before i was sure thats what it had said. d'ya reckon fsm were just lying? i dont know anyone who's used an additive in their niki fuel, and of all the problems i've heard, none have been valve related.
phreak97
