Author Topic: Starter?  (Read 5227 times)
bigjimmer
Starter?
« on: August 26, 2006, 08:49:56 PM »
How do's,
My grandad is currently attempting to patch any rust that is on my car and doing a good job at that. However, the car refuses to start. The starter refuses to turn and doesn't even click etc. It seems like there is no power to it. I have checked all the cables (including the starter lever) and there doesn't seem to be a connection problem, although i need to get under the car properly.
Apparently he tried to start the car whilst it is was in gear and then the motor would work after that. Surely this wouldn't burn out the starter and surely it wouldn't pack up just like that?
The only thing i can thing off is that the boot has been taken off, does anybody know if there is an earth connection to it? Or any other connections that may have been broken?
Any help would be appreciated,
Thank you,
James
Starter?
« Reply #1 on: August 26, 2006, 11:41:45 PM »
sounds like starter has gone, when your grandard said he started it in gear he meant he was bump starting the car this wouldnt damage the starter James (as far as i know)
i think u will need a recon starter, not too dear i think around £40-50 they are easy to fit.
i think the earth strap should be somwhere connected to the body, have a look for it.
regards
bigjimmer
Starter?
« Reply #2 on: August 27, 2006, 01:29:12 PM »
Thanks for your reply.
He wasn't trying to bump it, he accidentally tried to start it whilst it was in gear. Surely this wouldn't kill the starter just like that?
Do you know of any place i can get a spare?
richard
starter
« Reply #3 on: August 27, 2006, 02:58:28 PM »
ive got a starter
email me if you want ??
its off a 650 aircooled
the later one without the pull start handle on ..
bigjimmer
Starter?
« Reply #4 on: August 27, 2006, 04:30:12 PM »
I notice in another forum someone metions a burnt out starter lead. Does this sound possible? It would make sense that it burnt out during being used whilst the car is in gear.
Starter?
« Reply #5 on: August 27, 2006, 04:38:28 PM »
If it's an air cooled with the lever pull have you actually tried the lever on the starter motor?
bigjimmer
Starter?
« Reply #6 on: August 27, 2006, 04:52:42 PM »
Tried that. There are no clicks, nothing, zilcho signs of life. I just don't get how it would die just like that.
More expense.
Starter?
« Reply #7 on: August 27, 2006, 05:22:14 PM »
if your grandad had the car in gear with a good handbrake on,and persistantly pulled the starter lever,it would burn out,but.......he would have smelt/felt and heard it trying to push the car along........have you got good headlights etc????? just a test for the battery.........
next thing is,put car in gear,handbrake off,push it back and forth a few times.sometimes starters can get jammed in the flywheel if abused,this can free them off.
dont get down hearted,its only a starter motor,you could scrap a 500 for one........................you'd have to find one with original running gear first tho!!! :lol:
Starter?
« Reply #8 on: August 27, 2006, 05:40:49 PM »
If you do the rocking thing in gear use 4th gear. Is there power to the large cable on the starter?(should be live all the time)
I think that there is an earth strap located on the lower back panel which may be worth checking.
If I was you I would take the starter motor off it's then easy to check it with a battery and jump leads.
One other thing do the headlights go dimmer when you are trying to operate the starter?
bigjimmer
Starter?
« Reply #9 on: August 27, 2006, 07:03:32 PM »
He realised it was in gear straight away, he says it just refused to turn after that. We have tried with jump leads to no avail.
Good tip with the headlights dimming, i will try it tomorrow.
Thanks again everyone,
James
Starter?
« Reply #10 on: August 27, 2006, 07:12:24 PM »
mnn,sounds like he might have just fried a (bad ) earth with a short overload.....try looseing the earths and lives,waggle around(batt disconnected) then re tighten.....might do the trick..worth a try?
Starter?
« Reply #11 on: August 27, 2006, 07:56:53 PM »
Hi James. if you do what Cars and Dave said and check you have 12 volts on the red cable. if thats o.k. check the lever is operating the soleniod. where the green blob is. if it is the problem may be the copper connector bar in the soleniod thats worn, if you push the top of the soleniod an the motor spins  then that could be the problem.
Pete
totyfox
Starter?
« Reply #12 on: December 17, 2007, 08:19:52 PM »
what this lever connect to?
Starter?
« Reply #13 on: December 18, 2007, 05:04:57 PM »
this lever connects via a cable that runs under and through the center of the car to the starter lever which is just behind the handbrake .
totyfox
Starter?
« Reply #14 on: December 20, 2007, 08:58:28 PM »
behind hand break there is two lever and they are not connected to this my lever conected to the air at carburator
