Author Topic: Starter?  (Read 5227 times)
Starter?
« Reply #15 on: December 22, 2007, 10:57:27 AM »
yes one is the choke which is to the carbureteur. the second is to the starter motor . if not you may have only one lever as then it means you have an electric starter and is operated on turning the ignition key as normal cars do.  if your car is a lever starter you can still start up by using a piece of wood (if your cable is broken) turn on the ignition , make sure the car is in neutral, apply choke if needed, and push down on the starter lever with the wood . you can manually operate the throttle if needed from the rear as you do so. hope it helps mick.  another question is being in egypt , is the engine getting very dusty?
totyfox
Starter?
« Reply #16 on: December 22, 2007, 11:06:15 AM »
no the engine is clean i spry it with gasoline and make it clean ..many thanks i think i have electric starter thanks
jpimpao
Starter?
« Reply #17 on: December 22, 2007, 03:11:57 PM »
Have checked the wire from the coil to distributor, mine got lose one of this days and the engine dead
Jorge
