Author Topic: Ignition  (Read 4961 times)
Nurudin
Ignition
« on: July 31, 2006, 11:21:50 PM »
Hi all, I have read a lot about diffrent types of ignitions but I cant place mine in any of them. Here is a pic of it. Anyone can explain how it works an maintaines to detail or direct me to a site where i can find such info?
http://www.dropshots.com/day.php?userid=154505&cdate=20060731&ctime=173646
PaulB
Ignition
« Reply #1 on: August 01, 2006, 07:39:13 AM »
EDIT Its a Polish wasted spark dry coil. Very reliable.
Nurudin
Ignition
« Reply #2 on: August 01, 2006, 10:31:13 AM »
Does that mean it fires both plugs simultaneously?
PaulB
Ignition
« Reply #3 on: August 01, 2006, 10:59:08 AM »
Yes, I should be more careful how i describe things... its real name is a wasted spark system (I think twin spark is an Alfa engine which uses two plugs). I've now edited my post.
The voltage runs in serial from one plug to the next, but only the plug under compression will produce a big spark
The removal of the rotor, cap and a HT lead improves reliability. The weakness is both plugs form the circuit, so if you loose one lead or plug, the whole circuit is down. however, with these engines, you would barely move one cylinder anyway as bhp will drop to well below 50%, so it doesn't matter.
This system is used on Harleys and BMW airheads amongst others so has some pedigree.
Nurudin
Ignition
« Reply #4 on: August 01, 2006, 03:25:52 PM »
OK, here is what i have figured out:
When No. 1 cylinder is in compression stroke No. 2 is in exhaust stroke.
Firing of the No. 1 should be 10 degrees BTDC.
If it fires late the combustion will not finish before it goes in exhaust stroke
The exhaust valve opens and the fumes escape still burning
Could this be backfire im getting?
As the backfire is only there on high revs going downhill or when I release the accelerator pedal Im guessing my advance unit is not doing the job. Is my theory OK?
Where is the advance unit on my ignition and how do I check it?
That is why I asked about ignition type and how it works. Sorry if I have complicated everything too much but Im not sure I understand how things work, so want to be safe
PaulB
Ignition
« Reply #5 on: August 01, 2006, 08:47:28 PM »
The "advance unit" are two small springs attached to bob weights inside the distributor. They can get damaged, stretched etc. The easiest way to check advance is to use a strobe timing light. You are right about the backfire - its unburnt fuel exploding in the hot exhaust, and is usually a timing issue, but check your valve clearances too. I think a little bit of rumbling backfire on the overrun is quite common, but loud pops mean something needs tweaking.
Ignition
« Reply #6 on: August 01, 2006, 09:31:48 PM »
could also be a airleak on the intake or exhaust side of things?,my aircooler used to pop and bang on the overrun,one of the elbow gaskets had partialy blown............
Nurudin
Ignition
« Reply #7 on: August 01, 2006, 10:04:36 PM »
Ill try to do the valves, change the points and reset timing tomorow. I have heard that fiat 126 points are the same like on some other cars. Anyone knows which, cause it might be a problem finding them. As for the valves, how is it that they are always set to 0.20 and 0.25. Should there not be a bigger gap left as the cam wears out?
Nurudin
Ignition
« Reply #8 on: August 08, 2006, 11:53:39 PM »
It has proven to be a bit difficult to find points in my town. I have ordered them from another town but there has been some delay. :( Hope they come soon.
I have set the valves as specified. The backfire is now gone but there is some rattle and engine rocks on idle. Have checked the valve clearance when engine hot and noticed that there is some clearance left.
 Also there are five marks on the chain cover. The low/right one is TDC and the other four are about 3 mm apart, each, to the left/up. I have set the timing to the far left/up. Is this -10 deg?
And how to you set the idle speed? By ear or is there some other method?
PaulB
Ignition
« Reply #9 on: August 09, 2006, 11:40:49 AM »
Hi, the timing marks are, from top to bottom:
20 degrees BTDC
15 degrees BTDC
10 degrees BTDC
5   degrees BTDC
TDC
Setting Idle:
(This is a Fiat 500 carb, but its very similar)
(A) Idle speed screw: a sprung screw on the throttle arm of the carburetor, turning it speeds up or slows down idle
(B) Idle mixture screw: just to the right of the throttle arm, set into the base of the carburetor, turning it alters the fuel/air mix. They sometimes have a little cover though this is usually lost.
1. Make sure valves, points and timing are good.
2. Run the engine until it is nice and hot
3. Turn the idle speed screw until the engine is running at a speed you are happy with (about 900 rpm, but its normally by ear).
4. Adjust the idle mixture screw until the engine is running at its smoothest - close it and then slowly open it until its sweet.
5. Re-adjust the speed screw if necessary.
Nurudin
Ignition
« Reply #10 on: August 10, 2006, 12:42:36 AM »
Hi Paul,
just found this polish site and from a bad translation it seems that they think the timing marks are 10; 7,5; 5; 2,5 i 0 deg.
http://www.126fan.pl/
go to left side menu "Eksploatacija" and "regulacije"
PaulB
Ignition
« Reply #11 on: August 10, 2006, 07:54:21 PM »
If you have a timing strobe you can check:
1400rpm = 0 degrees advance
2000rpm = 10 degrees advance
3000rpm = 18 degrees advance
These are all approximate.
If you don't have a timing strobe, line up the timing mark on the pulley to 0 degrees (TDC), then 10 degrees is about 13mm before that. You can work out the others from that.
Nurudin
Ignition
« Reply #12 on: August 11, 2006, 10:02:39 PM »
Got the air filter and the points today. Trust you Paul with the timing, set that, set the valves and the mixture. Tomorow Im going for a trip to Banja Luka. 120 Km in one way. Ill let you know how it went.
Thanks again for the help
PaulB
Ignition
« Reply #13 on: August 12, 2006, 08:12:02 PM »
Better to check than trust me - I'm going by my engine - may not be the same as yours....  :D
