Author Topic: 126 ELX WIRING  (Read 2001 times)
derekscoopers
126 ELX WIRING
« on: June 25, 2018, 08:17:33 AM »
I am fitting a complete new 500r loom from Autobella to my 126 but need to refer to an original 126ELX diagram to convert, it's mainly the column wiring I am interested in to cross over, does anybody have a copy of that system ?
Re: 126 ELX WIRING
« Reply #1 on: June 25, 2018, 10:59:28 AM »
At a guess I would suspect that the Bis wiring diagram would be very similar to the ELX, especially if it is just the steering column wiring that's needed.
derekscoopers
Re: 126 ELX WIRING
« Reply #2 on: June 25, 2018, 11:10:55 AM »
Thanks Chris, found a couple on a Polish site but all in Polish !!
I am doing away with most switches on the stalks just want to know what they did and what wires to remove
Will look at the Bis diagrams
derekscoopers
Re: 126 ELX WIRING
« Reply #3 on: July 02, 2018, 06:19:59 PM »
well the Bis diagram helps a bit but have a question somebody may know the answer to,
The engine I have fitted has a pre engaged starter, and as well as the thick brown wire it has a red slightly thinner wire in a lucar connector right next to the main nut connector for the brown, this red wire does not appear on any of the diagrams I have, and I have quite a few !!
also does anybody have an old standard regulator box for sale , I dose not need to be  working, just to use for wire connections to the alternator, unless any other suggestions to keep the wires tidy.
