Author Topic: Accelerator  (Read 2111 times)
Accelerator
« on: June 26, 2017, 08:59:38 AM »
When I take my foot off the accelerator, the engine does not idle straightaway. It sort of drops to idling rev gradually. A spring might have come loose somewhere. Any thoughts?
Cheers,
Angelo
Bar Vitelli
Re: Accelerator
« Reply #1 on: June 26, 2017, 09:02:16 AM »
Could just be a bit rusty if you have not used it for a while, happens occasionally on mine, take it for a long drive and it should sort itself.
Every cloud has one...
Re: Accelerator
« Reply #2 on: June 26, 2017, 09:19:42 AM »
Yes, it is probably partly due to lack of use. I couldn't see anything obvious visually from the engine compartment. I can rev it by moving the accelerator throttle lever by the carb, which springs back into its normal position.
Could it be the accelerator level spring?
midvillesb
Re: Accelerator
« Reply #3 on: June 26, 2017, 04:38:17 PM »
The problem is more likely to be at the pedal end.  The pedal shaft runs through a tube across the footwell and that can get rusted/gunked up - best thing is to unbolt the whole thing and then give a liberal squirt of WD40 to get between the shaft and the outer tube and then work it loose.  I had the same problem on my old BIS and that fixed it... Mike
Re: Accelerator
« Reply #4 on: July 08, 2017, 10:30:10 AM »
Many thanks. i shall have a go at it.
Cheers,
Angelo
