Author Topic: BIS compression testing.  (Read 3894 times)
« on: April 15, 2017, 05:56:32 PM »
Just a quick question I'm gonna try and give my car a compression test tomorrow but I can't seem to find any info on what pressure reading I'm supposed to be getting? Has anyone ever done one on a BIS?
Re: BIS compression testing.
« Reply #1 on: April 17, 2017, 09:17:35 AM »
Ok I managed to kind of do one. I say "kind of" as I couldn't do the number 2 cylinder (gearbox side) as my compression tester won't fit past the carb but I was able to do the rear one and I got a reading of 125psi (9.5bar) so because no one has done a compression test on a BIS before I hit the Internet for some typical compression test figures and found out that your supposed to do the test with the engine hot AND with the throttle wide open both of which I didn't do so with that in mind I reckon that 125psi in fact probably higher so I'm happy with that...... Just wish I could've done the other   ::)
« Last Edit: April 17, 2017, 09:52:28 AM by Gadge »
Xylaquin
« Reply #2 on: April 17, 2017, 09:43:52 AM »
Compression ratio is listed as being 8.6 bar (plus or minus 0.15 bar)
« Reply #3 on: April 17, 2017, 09:51:34 AM »
8.6 bar  :o wow it's got a good seal then  ;D
Incidentley where did you find that I searched around and couldn't find anything?
drcdb15
« Reply #4 on: April 17, 2017, 09:04:13 PM »
A friend was doing some compression testing on his Lotus recently and got figures ranging from under 100psi to around 125-130, so your 125 sounds healthy enough. The main point is not the absolute figure but any discrepancy between cylinders. The closer the two are the better. I'm afraid your rear cylinder reading isn't very much value (other than saying at least one cylinder is OK) without the reading for the other one to compare with. Given the space constraints and your well-demonstrated engineering expertise can you not make up some angled adapter tube thingy to get into the space?
Xylaquin
« Reply #5 on: April 17, 2017, 09:18:19 PM »
1. Haynes sheet in the subscriber section
2. Page 12 of General Information in the workshop manual
The problem with your engine Gadge, is you've modded it. So how can you tell what you're meant to get 🤔
« Reply #6 on: April 18, 2017, 06:25:46 AM »
While that is true I'm only looking for a rough idea. I run a standard BIS block and a cinquecento head so I guess I'm after either a cinquecento 700 figure (if there different) or a BIS figure. What I should have asked originally is what is everyone else getting but I didn't think a lot of people would have done one. I'm
Not suspecting a problem with it I'm just st curious
drcdb15 Yes I really do need to do that front cylinder. I don't have the materials to make an adapter although the simpler solution would be to remove the carb but it can be a fiddley job on a BIS
drcdb15
« Reply #7 on: April 18, 2017, 08:42:29 AM »
How about something like this little gadget? Under £25 and seems to be flexible and adaptable, if you'll pardon the pun.
https://www.tradecounterdirect.com/product/sealey-petrol-engine-compression-test-kit-8pc-set_engine.html?gclid=CPSKye6_rdMCFUu3GwodYdgIaA
You might even pick up a used one on fleabay for less.
« Reply #8 on: April 18, 2017, 12:45:59 PM »
Ahh yes that would be a better one. I have a gunson one and it has an unusually long threaded end on it - about 5 inches I'ld say
drcdb15
« Reply #9 on: April 19, 2017, 11:39:02 PM »
Five inches? Well don't feel bad about it Gadge, size isn't everything ...  :P
« Reply #10 on: April 20, 2017, 04:58:04 PM »
It's a cross I have to bear bud  :P
