Author Topic: Engine #2 Potentially toast! ._.  (Read 2751 times)
Club1n
    • Hit me up on Facebook!
« on: December 17, 2016, 05:33:28 AM »
2nd engine in my BIS,  I think I may need to do a headgasket.. ;) Hopefully this time I won't find broken valve springs or smashed cylinder walls! Engine came out of a parts car with 30k miles, glad I've got a vast collection of BIS bits! Lets hope for no head warping  :P
« Last Edit: December 17, 2016, 06:22:49 AM by Club1n »
                                     1978 Works Fiat 126 Rep.
Re: Engine #2 Potentially toast! ._.
« Reply #1 on: December 17, 2016, 10:25:07 AM »
just needs a new head gasket and a skim, and get rid of the thermostat so it doesnt boil up again...
« Reply #2 on: December 17, 2016, 10:45:00 AM »
And give it a good bleed when your refilling! I found it best to remove the temp sensor, top radiator bleed screw  and the bleed screw on the heater and fill the system gently waiting for water to come out of first the top of the radiator then the temp sensor then after you've screwed them both back in, run the car with just the heater bleed open then as it warms up screw it back in.
 Trapped air is probably the biggest cause of blown head gaskets on BIS models as there are so many corners and nooks that air can stay. With the fact that the radiator has very little airflow and the thermostat located at the bottom of the engine, a water pump that runs off a shaft that's powered by the camshaft and enough coolant hoses to wrap around the car It's probably the most awkward and complicated cooling system I've ever worked on and does work as designed but everything has to be in good shape that includes making sure the fan cuts in (both times as it has a slow setting and a fast setting for when it gets hotter)
Club1n
« Reply #3 on: December 17, 2016, 10:59:25 PM »
Thanks for the info guys! Thermostat has already been removed, just gotta wait until I have a free couple of days! Easiest way to change 'em is dropping the engine I guess? Seems the easiest way to do anything on her, haha! :P
« Reply #4 on: December 18, 2016, 08:03:59 AM »
Yep drop the engine I did it in situ and it was a pain.
« Reply #5 on: December 18, 2016, 09:24:10 AM »
For the sake of a few extra bolts it's worth just dropping the lump out. You can look at other things like the crank seals, clutch and clean the oil filter while your at it :thumbup
Lloyd74
« Reply #6 on: January 08, 2017, 07:39:55 PM »
I got mine skimmed and did all the usual, I was getting 1500miles to a head gasket until old creamy would rear its ugly head, the problem for me was ebay gaskets that have been sat around for too long, fitted a copper one and this stopped dead in its tracks
Club1n
« Reply #7 on: January 08, 2017, 08:16:09 PM »
Gonna put an ebay one in this time, I don't really do many miles but next toasting i'll probably go copper :P
