Author Topic: Brake hose recommendations  (Read 2531 times)
Joe Webb
« on: September 02, 2016, 12:50:45 PM »
Hey, does anyone know a good brake hose to use with the seicento brake upgrade? The original ones seem a bit long?
Thinking of braided hoses but not sure if they are worth it
Anyway, would appreciate anyone's advice
Cheers!
Joe
Re: Brake hose recommendations
« Reply #1 on: September 02, 2016, 03:20:56 PM »
I had a set of braided hoses made up as they didn't seem to be the right length off the shelf ( although other people may have ideas) and local hydraulics company should be able to make you a set
Joe Webb
« Reply #2 on: September 02, 2016, 04:45:06 PM »
Interesting, do you remember what length and how much you paid?
amam
« Reply #3 on: September 02, 2016, 05:48:29 PM »
when i did my disc brake conversion i was told to use punto brake hoses but they are way too long
so i searched until i found these, right thread and still used on models of fiat/alfa but about 2/3 the length of punto ones, they are just the right length
http://www.ebay.co.uk/itm/271787059762?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
NathanMcM
« Reply #4 on: September 03, 2016, 02:31:53 AM »
Joe would you recommend the seicento front brake conversion?
Retro as f**k.
« Reply #5 on: September 03, 2016, 09:23:42 AM »
I just used braided ones for a 126? The banjo Union hangs down more than I would like on the caliper but at the right angle it clears the suspension lock to lock.
Joe Webb
« Reply #6 on: September 04, 2016, 09:26:05 AM »
I would definitely recommend the conversion nathan, but don't buy the kits cause they are overpriced, buy the calipers from breakers yard and make sure they send you the banjo bolts and other fittings
Yeah I'm sure i can get 126 ones to fit, but are custom length ones much more expensive?
NathanMcM
« Reply #7 on: September 04, 2016, 09:55:45 AM »
What all parts did you need Joe? Adapter plates discs and calipers?
Retro as f**k.
Joe Webb
« Reply #8 on: September 04, 2016, 10:11:45 AM »
Yeah that's it Nathan, and brake pads of course
I don't think they fit under the original 12" wheels though so you'll also have to find some 13" et38 5j wheels and tyres. That's the priciest part.
NathanMcM
« Reply #9 on: September 04, 2016, 03:40:48 PM »
Have you done this to your 126 yet? And lucky that I've x19 wheels to put on mine
Retro as f**k.
Joe Webb
« Reply #10 on: September 04, 2016, 04:44:17 PM »
Yeah I have, it's really straightforward.I put some Uno wheels on mine, msw alloys i think
Good luck then!
