Fiat 126 Chat
Oil filter
Pages: [
Topic: Oil filter (Read 1962 times)
Da Londo
It's not the carb size that matters, it's the jet
Oil filter
on:
July 12, 2016, 05:25:16 PM »
I inspected my oil filter today and found the shim bent, is this factory standard?
http://jimsfiat126.blogspot.be/
Subscriber VIP+
Re: Oil filter
Reply #1 on:
July 12, 2016, 07:20:54 PM »
That looks nice and clean in there. I think that the part you are calling a shim is actually the crankshaft retaining hollow bolt tab washer which you bend onto the nut after you have torqued it up and stops your crankshaft from going walkabout if the bolt worked loose
ronb1967
Subscribers
Member
Re: Oil filter
Reply #2 on:
July 12, 2016, 10:01:00 PM »
yes i agree its a lock tab
Da Londo
Re: Oil filter
Reply #3 on:
July 13, 2016, 10:57:25 AM »
Aha! So when I replace it I'll bend it again. Thanks!
Joe Webb
1999 Fiat 126p elx, 1981 Matra Muren, 1971 Greeves
Re: Oil filter
Reply #4 on:
July 17, 2016, 01:06:17 PM »
I replaced the front oil seal recently and realised I'd forgotten to bend the new washer up after I'd reassembled and remounted the engine...
All better now though
Pages: [
Fiat 126 Chat
Oil filter
