Author Topic: Changing Oil Seals  (Read 1797 times)
danthemanic
  • 1987 Polski A/C
Changing Oil Seals
« on: June 17, 2016, 09:38:25 AM »
Hi All,
I'm planning on replacing the oil seals this weekend as it has been seeping for a little while now.
I've searched other threads, and people say its an easy job.  Can someone please give me a quick step by step?  It's not a job I'm familiar with.  Do I need to get the car on a ramp, or can it be done jacked up, on stands etc?
Bambino126
Re: Changing Oil Seals
« Reply #1 on: June 17, 2016, 10:49:02 AM »
There are very many oil seals and gaskets on an engine, which specific ones are you wishing to change?
Do you have an Air-cooled, or a Bis?
Bambino126
« Reply #2 on: June 17, 2016, 10:52:50 AM »
I'm guessing you might mean the crankshaft oil seals? If so then yes it is reasonably straight forward, I've done it on my Bis, the front one (where the oil filter is) can be done in situ, but the rear one behind the flywheel is obviously an "engine-out" job.
danthemanic
  • 1987 Polski A/C
« Reply #3 on: June 17, 2016, 11:47:51 AM »
Driveshaft oil seals, sorry.
It's an aircooled model.
