Author Topic: Positive camber  (Read 2212 times)
DannyPancho
Positive camber
« on: June 12, 2016, 05:47:27 PM »
Whats the options for getting rid of the positive camber on the rear wheels? Also, the back right has more camber than the left...
Any help will be great
Thanks!
Dan
Fiat 126 DeVille
Re: Positive camber
« Reply #1 on: June 13, 2016, 06:37:27 AM »
Hi Danny because of the simple way the rear arms swing up and down the only way to sort out rear camber is to lower it. The lower you go the more negitive the wheels become. If you are expericing more camber on one side then perhaps you have a duff spring or shock
DannyPancho
Re: Positive camber
« Reply #2 on: June 13, 2016, 11:23:27 AM »
Fantastic! thats really helpful thanks Gadge   :D
Fiat 126 DeVille
Bambino126
Re: Positive camber
« Reply #3 on: June 17, 2016, 11:27:10 AM »
Hi Danny, I had the same problem as you, and lowering helped a lot.
I cut 1 and ¼ coils off my rear springs and it reduced the positive camber from +4° to just +1°.
I would have liked to go lower still to get into negative camber territory but the car was getting too low.
Only an inch away from sitting on the bump stops so not a lot of suspension travel.
Some people say you can reduce the positive camber by putting shims or washers behind the hub, but after studying the design of it I didn't like that idea so went down the lowering route.
The swinging arm rear suspension seems a pretty flawed concept to me. I mean having to fill your car with 4 people and a boot full of luggage just to compress the rear springs down enough to delete the crazy positive camber angle seems madness. All that weight isn't gonna do any favours for acceleration or fuel economy. All my journeys are on my own and without luggage which is why I reduced my spring height.
Running with +4° I had two problems - The outer edge of my tyre was worn out every 1500 miles, and also with the tyres 'tucked in' at ground level the car felt like it wanted to roll over every time you tried to corner with any speed at all.
Xylaquin
Re: Positive camber
« Reply #4 on: June 19, 2016, 05:09:43 PM »
Whenever I lift the rear end the camber shows, but then I drive one half of the car onto the pavement then abruptly drive off. That seems to sort it for me
