Author Topic: Fiat 126P RHD  (Read 11342 times)
DannyPancho
Fiat 126P RHD
« on: December 08, 2015, 01:48:00 PM »
Hi! im in desparate need of finding a 126P in right hand drive! No matter what i do, i cant find one anywhere for the money i have! if anyone knows of one or has one which is in good working order (doesnt have to be great) (as long as the thing is drivable then im willing to think about it!) as it stands a LHD in my oppinion isnt the best for the UK but RHD is seemingly hard to come across... :cry:
thanks in advance
Fiat 126 DeVille
Xylaquin
Re: Fiat 126P RHD
« Reply #1 on: December 08, 2015, 05:31:40 PM »
How much money do you have?
I don't think there is such a thing as a RHD 126p, the p stands for Polski, models for the European market up until 2000.
The latest UK model would be a BIS.
DannyPancho
Re: Fiat 126P RHD
« Reply #2 on: December 08, 2015, 06:49:55 PM »
True! Unless all RHD 126's that arent the Bis are 'Browns' then i dont stand much chance because theyre meant to be quite rare! As its stands, i would spend about £1,300 as a limit  ;D
Fiat 126 DeVille
Re: Fiat 126P RHD
« Reply #3 on: December 08, 2015, 07:18:44 PM »
You'll be very lucky if you can pick up a decent aircooled 126 for £1300. MOTed rhd cars are starting around £2000 - bis versions are cheaper but less desirable. Polish imported 126 (lhd) could be had for £1500 for a decent drivable one but you'll need to get it registered. One that are registered will be more. I'm afraid prices are on the up
DannyPancho
Re: Fiat 126P RHD
« Reply #4 on: December 08, 2015, 07:34:43 PM »
Thats what i was dreading  :$ i guess ill have to leep saving or stuff it and gor for a LHD! Ill just keep scrolling the classifieds! Cheers  :P
Fiat 126 DeVille
Re: Fiat 126P RHD
« Reply #5 on: December 09, 2015, 09:52:34 AM »
 Go for a left hooker, just make sure you check everywhere for rust. Those later models are even more rust prone.
 There are quiet few on Gumtree at the moment and some that look half decent for under a grand.
 They are of course still on Polish plates, but this will give you a bit of leverage on the price and the registration process is not that difficult.
 As the guys said on the road rhd air cooled cars are more like 2k at the moment, unless you are prepared to take on a project.
 BTW most of the air cooleds including rhd after cca 1980 were built in Poland so they are technically a Polski.
DannyPancho
Re: Fiat 126P RHD
« Reply #6 on: December 09, 2015, 04:39:42 PM »
I have taken your advice and gone onto Gumtree, its fantastic! i think i will go for a LHD because theyre so much cheaper :P do you have any experience of driving a LHD in the UK? I believe it would be fine but others say that it could be difficult... any thoughts? Cheers!! :D
Fiat 126 DeVille
Xylaquin
Re: Fiat 126P RHD
« Reply #7 on: December 10, 2015, 01:45:18 AM »
I've never done it, but I imagine the only thing would be you're used to reaching out for the gearstick with your left hand instead of your right.
Oh and going through drive-thrus will be fun ::)
I've sent you a PM!
Re: Fiat 126P RHD
« Reply #8 on: December 10, 2015, 08:11:27 AM »
 With a small car like a 126 lhd isn`t really a problem. The biggest issue is when you have to overtake and you haven`t got a passenger in the car to look for you :)
 I also find the pedals work better for me in a left hooker.
DannyPancho
Re: Fiat 126P RHD
« Reply #9 on: December 10, 2015, 07:45:27 PM »
haha yeah thats true, its only 1.3 metres wide??  :P how so? is it becasue of the wheel arches in the footwell or something like that?
Fiat 126 DeVille
drcdb15
Re: Fiat 126P RHD
« Reply #10 on: December 11, 2015, 10:54:14 PM »
Most cars made outside the UK and Japan are primarily for a left-hand drive market. When a right-hand drive version is made, pretty much all of the front occupant's area is simply mirror-imaged across from left to right. Hence all the geometry of the design is perfectly replicated and looks the same, just 'back to front'.
However, the foot pedals cannot be treated like this or the usual L-R arrangement of clutch/accelerator/brake would be reversed. The pedal assembly has to be carried over unchanged - complete with its own geometry - and somehow fitted into the available space on the other side.
Most cars are pretty tight for space in the footwells, especially if there's a transmission tunnel, or in a short wheel base car where the wheel intrudes into the footwell. The original left-had drive pedal assembly is usually carefully designed for an optimum fit into the left hand well. Almost by definition, then, if you now transplant that arrangement onto the other side, without mirroring it, the fit will be non-optimal. Where your left foot, for example, had plenty of room by the inside of the front wing, it is now squeezed up against the centre console - and so on.
If you look at the exact components of the pedal controls in left and right hand drive versions, it is very typical to see some very elegant design on the LHD one, but the RHD one is a complete hotch potch of extra extension bits and secondary levers and dog-leg bends etc to try to get the fit into some sort of usable position.
There is a good example of this on the 126, with the throttle pedal. On the LHD it is right next to the centre tunnel, and the cable link is nice and neat. On the RHD version, the pedal is now on the outside edge of the car, and Fiat have used the long rod rotating in the tube that's bolted to the floor to carry the pedal's movement across the footwell to the centre tunnel, in an area subject to dampness from a wet British driver's foot. So not only is the mechanical arrangement poor, it is placed in a region that is wet, dirty and impossible to lubricate - which is why it is a classic seizure point on British cars that our Italian and Polish cousins have never had the pleasure of experiencing!
Ladislav finds the LHD pedals easier to use for the simple reason that they are properly designed, whilst the RHD drivers have to put up with what is essentially a production botch.
drcdb15
Re: Fiat 126P RHD
« Reply #11 on: December 11, 2015, 11:10:44 PM »
Another more extreme example of this can be found on another Fiat, the Idea MPV. A friend of mine had one of these, and the ABS pump failed. Simple job, just get a recon one and swap it over....
Not so. After months of searching, and two garages returning the car having given up on it, another friend sourced one in a scrappy in Germany of all places. Oh come on, I said, how can it be that rare, it's only an ABS pump, are you telling me Fiat made a special pump JUST for the UK market, and JUST for that one model (most Idea parts come from the Punto, it seems).
Well it turned out the answer is "yes" - in converting the originally LHD Idea to RHD for the UK, Fiat faced an insurmountable problem - if they fitted a RHD pedal box, they couldn't leave the standard ABS pump where it was on the other side of the bulkhead. But if they kept the pump, they couldn't fit a RHD pedal box...
On the LHD car, of course, the pedal box and ABS pumps were on opposite sides of the car. In converting from LHD to RHD you don't need to move anything in the engine bay except the steering mechanicals.
They couldn't do anything about the pedal box, that HAD to be in the usual RHD position, so they had no choice but to do something about the pump. They resolved this by placing the ABS pump in a slightly different location, but one where the standard pump wouldn't fit. Obviously they didn't find any other option, and they ended up making a bespoke pump just for that one model and just for the RHD markets... oops!!
It is no coincidence that the Idea was only sold in the UK for about 3 years, and was something of a commercial failure.
DannyPancho
Re: Fiat 126P RHD
« Reply #12 on: December 12, 2015, 01:00:05 PM »
wow :o good god that was useful! okay ill take all that into account when looking; sounds like a LHD is the way to go for just about every reason i can think of now! thankyou very much  :D
Fiat 126 DeVille
alastairq
Re: Fiat 126P RHD
« Reply #13 on: December 12, 2015, 02:31:38 PM »
LHD should not be an issue for a driver. Unless one is the sort of driver who is less than unhappy driving  less than 2 seconds behind the vehicle in front?
Overtaking merely involves thoughtful positioning to obtain a decent view ahead.
However, LHD can confuse other road users, as the driver of a LHD vehicle may well adopt a slightly different position at junctions, etc, in order to see clearly.
[I have often driven LHD military Landrovers....a bit of a pain when dealing with roundabouts, since they don't have windows behind the doors. So, when one considers at most UK roundabouts, one presents oneself  at an angle to the road markings prior to entering, doing likewise with the Landrover completely masks ones view to the right!! One ends up, effectively, pointing in a an entirely different direction to everyone else in order to see to the right!!  Good fun on motorways, however, as when being overtaken, there is, apparently, no driver!!]
I have recently purchased a 126 bis for the princely sum of £250.
It runs, it drives, it needs some bodywork attention, but seems essentially sound.  It needs its [back, especially] brakes re-commissioning...then engine will need a service.....for the moment...and, given the weather, all I have really done is de-seize the throttle pedal.
Oh, and put a nice big order into 126fan shop, for a big box full of panels and stuff.   Cheaper than patching and so on.   :)
mintex
Re: Fiat 126P RHD
« Reply #14 on: December 12, 2015, 03:02:59 PM »
Dont dismiss a rhd model if it shows up though  :D
Dave
