Author Topic: cams  (Read 20729 times)
cams
« Reply #15 on: June 05, 2006, 09:20:16 PM »
totaly edited,just me being frustrated at not havin my little car!!!!!!!!!!!!!!!!.
sorry to anyone who was slighted in anyway
PaulB
cams
« Reply #16 on: June 05, 2006, 10:58:46 PM »
try pasquale at turbo1sport - he sent me photos of everything laid out before I paid him. Top man. Also found 500Mania quite quick and not too badly priced.
hudsonhenry
    • http://www.retro500.com
cams
« Reply #17 on: June 06, 2006, 10:03:23 AM »
Dave
I have a whole engine that I am thinking about selling if you are interested.
I have now fitted the 1108 fire engine into my 500 and should have it running at the weekend. If all goes well I won't be needing my aircooled any more. I spent a fortune on it and its quite nippy (Chris has been for a spin with me, ask him)
I will give Ruud a chase for you, I have always found him to be realy good, will let you know
Nigel
hudsonhenry
cams
« Reply #18 on: June 06, 2006, 10:16:34 AM »
Dave
I have just spoken to Ruud, He has just got back from a fortnights holiday in Greece. He says he posted you brakes two and a half weeks ago, he is going to pop home and get the post reciept and email you the tracking number.
Hop this helps
Nigel
cams
« Reply #19 on: June 06, 2006, 01:06:18 PM »
hi nigel,yes,ruud has sent me a mail explaining all,his vacation timing coincided with the brakes going missing,so a public apology from me is in order  :oops:
as for your motor,well,im well into mine now,i would have bought it a few months ago tho!,it is fun tho frustrating at the same time!
cams
« Reply #20 on: June 15, 2006, 07:31:46 PM »
star date 15...06...06.captains log............well,parts turned up from Nanni......engine rebuilt,all lookin pretty,just have to ''adjust'' rear engine mount to clear modded timing cover/oil filter housing.................................then plumb in oil pressure gauge and oil cooler etc..hard wire the rev counter and the car should be running again,sadley,my brake kit seems to have gone missing in the post tho  :cry: ..........................
cams
« Reply #21 on: June 15, 2006, 10:19:58 PM »
Silly question, how much has gone into your little 126 so far? (we won't tell the wife) :lol:
cams
« Reply #22 on: June 16, 2006, 06:38:57 PM »
dunno how many £ or euro...............i learned a long time ago not to keep accounts of the cost of love affairs........................................ :lol:
cams
« Reply #23 on: June 16, 2006, 09:41:20 PM »
Are you talking about the wife again?
cams
« Reply #24 on: July 06, 2006, 06:21:59 PM »
well i can report the car was running very well with new cam /oil cooler etc etc etc installed......i say was,because the dreaded vibration has destroyed my MK.3 attempt at a carb steady...so top engine tin off again,re braze and reinforce from below,then respray etc etc.......... :roll:...........still,it gives me time to play with my front suspension
hudsonhenry
cams
« Reply #25 on: July 06, 2006, 10:04:39 PM »
What carb are you running?
cams
« Reply #26 on: July 07, 2006, 07:35:20 AM »
hi Nigel,40 DCOE,mounted on pirelli spacers,and suported  at the other end by a custom brkt mounted under the ram intakes,the bracket in the last ''tipo'' went down through the top tin,(brazed and extra metal collar added) then turned and sat on the second skin in a pool of silicon to try and dampen any vibes......
somehow the top skin has fractured around my reinforcing metal.....by the way,all the above was done with the motor on the bench and everything was ''relaxed'' as it was fabricated.also,the motor has not been ragged since fitting,still running in the cam etc.
any ideas most welcome,
meanwhile i am going to strip it out and ditch the silicon idea,braze another plate across the bottom skin,then refit all the other bits.......i do get the feeling im going to be chasing this one for a while..............
i will beat it!!  :twisted:
hudsonhenry
cams
« Reply #27 on: July 07, 2006, 09:21:04 AM »
Dave
I used to have a twin choke Delloto DHLB on my aircooled, it was supported by a bracket coming off the plate that the air filter attached to, this came down about 1 inch then turned 90 degrees, attached to this was a rubber and metal exhaust bobbin. The bottom of the bobbin was bolted to a 'u' bracket which was welded to the top of the shroud. I don't know if this makes sense but I will try to dig out a picture for you. This worked well as the bobbin acted as vibration absorber. I did have to occasionally replace the bobbin as the vibration would eventually seperated the rubber from the metal but it only took a couple of mins compared to hours of stripping and re-welding.
I solved the problem completely by dropping the twin choke and using a FZD, this was far superior to the twin choke, gave more peak power and a much better curve throughout the rev range. We tried lots different venturi sizes on the twin choke and had it working quite well but it was never as good as the FZD. The problem we found was that unless we used smaller venturies the peak power came in far too high up the rev range.
Are you using a Panda 30 twin port head? if so then a choke per port is a good idea, if you have a single port head then there is no benefit to using a twin choke.
The other thing that contributed to less vibration was having the engine balanced.
Hope this helps
Nigel
cams
« Reply #28 on: July 07, 2006, 06:31:49 PM »
hi nigel,thanks for the input,yes,im running a panda 30 twin port head,slack day at work today,so all is brazed/painted and ready to go again,fitting all tomorrow.
the reason i didnt go down the 'bobbin' route was because the carb was vibrating too much already,causing reversal,i needed a firmer fixing,the system i had worked great till it broke.......................
anyhow,all done now and back on the road tomorrow...........i also found the bell crank for the (standard) throttle linkage was vibrating,so ive drilled and tapped that,and fitted a cute little grub screw with a ball in the end to preload the linkage
as for dif carbs etc,no rolling road here,so im just giong on accepted 126 euro folklore on whats what to fit. it looks goes and sounds well with the bits i have fitted,bogs a bit from idle but thats ok....sounds great when on full throttle,cannot wait to wind it up a bit more,i will be keeping a red line of 5000ish for my un balenced motor
hudsonhenry
cams
« Reply #29 on: July 07, 2006, 07:48:50 PM »
Dave
Hope you have sussed it. I tried a few different methods before the bobbin, it was the only method I could find that did not move too much but also did not suffer from stress fractures.
And a couple to make you smile (or gag)  :shock:
Nigel
