Author Topic: cams  (Read 20755 times)
cams
« Reply #30 on: July 07, 2006, 08:33:57 PM »
cool nigel..........not sure about whats left of that 500,they so cute,why do that?...
anyhow,one more try down my route,i have another top tin coming i hope,if i need to i will try your method...............good pic,i like your detailed workmanship,very nice to see that attention to detail,you know what i mean. :cool:
cams
« Reply #31 on: July 07, 2006, 08:34:55 PM »
what the hell they have put the engine in the front!!! is that the body shell on a chassis?
regards
cams
« Reply #32 on: July 07, 2006, 08:38:12 PM »
god knows chris,twin cam somthing,prob alfa/fiat,,,space frame maybe?..very nice i expect but not my cup of vino.....................nice pic tho nigel!
cams
« Reply #33 on: July 11, 2006, 07:36:07 PM »
update,motor holding together........running well,am thinking of lightened balenced flywheel and fan from nanni next....any thoughts anyone?   :cool:
PaulB
cams
« Reply #34 on: July 11, 2006, 09:59:38 PM »
Why not use a 500 flywheel?
cams
« Reply #35 on: July 12, 2006, 06:09:28 PM »
mmmn,had not thought of that,is there a lot of difference in the two??......and,if so,,who has one going spare??
hudsonhenry
    • http://www.retro500.com
cams
« Reply #36 on: July 12, 2006, 06:45:35 PM »
I didn't realise that the flywheels were any different. :shock:
As I understand it the flywheels were balanced with the cranks (to a degree)  so any new flywheel will need balancing. This should be done with the crank and the oil filter assembly for best results.[/i]
cams
« Reply #37 on: July 12, 2006, 07:15:16 PM »
ahh......learning all the time.........
hudsonhenry
cams
« Reply #38 on: July 12, 2006, 07:56:05 PM »
Quote
Tis true...... now where did I put that book on exhaust design and fiberglassing?????
PaulB
cams
« Reply #39 on: July 12, 2006, 09:58:33 PM »
I've just weighed a 500 flywheel on some very crap scales and it came in at 6kg. If you like, I'll try and find something more accurate as i think those scales are off. My flywheel isn't available I'm afraid, but maybe Richard has one? or ask on the 500 board.
I think the Abarth 595 flywheel was 5.6kg, but i've heard of them down to 3kgs. I'd be worried about one that light in a 126 as they serve to dampen vibration as well as provide momentum.
I read somewhere that flywheels where different between early and later 126s.
cams
« Reply #40 on: July 13, 2006, 09:48:27 PM »
hmmnn...i only thought of a lighter fly wheel because my little motor is not as 'snappy' on or off the throttle as id like.....makes fast changes/double de clutching down a bit cumbersome............pedals are perfect for heel an toeing,but motor is not quite up to it........ :cool:
