Fiat 126 Chat
About contact points.
Pages: [
Topic: About contact points. (Read 2187 times)
AvB
Subscriber VIP+
on:
August 28, 2015, 02:30:35 AM »
Hello folks!!
Today on the first try to start the engine i got an explosion coming out of the exhaust system. Fearing it was the Contact points i removed the distributor cup and the rotor to find that the contact points where in bad shape !!!, I've remove the old one and replace it with a new one, now everything appears to be OK.
My question is, how long as i have to change for a new contact point , is it for time or mileage ??
I've set the gap of the contact breaker points to 0.42mm. Is this correct? i have read somewhere that Haynes suggests from 0.37mm to 0.43mm, but Fiat recommends from 0.47mm to 0.55mm, both of them are correct?
Last Edit: August 28, 2015, 04:38:49 AM by AvB
mile
Member
Re: About contact points.
Reply #1 on:
September 01, 2015, 04:36:40 PM »
126 bis
Marelli distributor 0,4 mm +-0,03
Zelmot distributor 0,47 to 0,55 mm
best 78 +-1 degrees
control was every 10,000 km, replacing if necessary
126
0,47 to 0,53
78+-1 degrees
Last Edit: September 01, 2015, 04:50:57 PM by mile
Administrator
Reply #2 on:
September 01, 2015, 06:07:29 PM »
It's always worth checking the ignition timing after the contact points have been set up.
AvB
Subscriber VIP+
Reply #3 on:
September 06, 2015, 02:14:56 AM »
@Chris and @mile
Thanks for the info. Im using the Zelmot Distributor and the gap is 0.42MM , and also i did check the ignition timing, everything its working really smooth so far xD, hope it will continue that way!
Cheers,
Pages: [
Fiat 126 Chat
