Author Topic: Does standard exhaust fit Panda 30 head?  (Read 2414 times)
drcdb15
« on: July 08, 2015, 03:42:23 PM »
OK folks, silly question time:
Can I fit a standard 126 a/c exhaust to an engine fitted with a Panda 30 head? I would guess from the dearth of anyone mentioning this on the Forum afaics that it is just a bolt-on fit... but is it?
As well as mating up the exhaust flange to the mounting studs on the head, does the exhaust bore itself mate up with the same diameter (I am assuming a standard 30 head, not one that's been flowed and opened up etc).
And do the mounting brackets/fittings for the silencer etc line up ? For example, if the 30 head had the same holes but, say, a few mm higher on the engine, or rotated a few degrees away from the 126 orientation, then the mounting points lower down for the silencer presumably wouldn't align properly.
Thanks for your thoughts.
Re: Does standard exhaust fit Panda 30 head?
« Reply #1 on: July 08, 2015, 08:48:53 PM »
I have a standard type sports, non modified, exhaust fitted to my panda 30 head no problems.
drcdb15
« Reply #2 on: July 11, 2015, 10:18:37 PM »
Thanks Ralph, for that reassurance  :D
