Author Topic: What size oilpan do I need?  (Read 2289 times)
Da Londo
    • Fiat 126 blog
« on: June 18, 2015, 10:53:37 AM »
I see all defferent sizes from 3,5 up to 5,5 liters. Which one to choose?
It will be needed for a 650 with FZD 32.28, sportscam and exhaust. The car will be used on the road.
Mics126
Re: What size oilpan do I need?
« Reply #1 on: June 25, 2015, 10:11:19 PM »
as long as your not giving it a boot full constantly then the 3.5 should be more than enough. do you have a oil temp gauge because then you would know if you need a larger sump or not.
Piotross
« Reply #2 on: June 25, 2015, 10:26:26 PM »
If you need is for road use buy a 3.5 liters oil pan
