Author Topic: tyre sizes  (Read 3361 times)
mintex
tyre sizes
« on: May 19, 2015, 09:30:43 PM »
do you think my tyre sizes are a little to big? and how much will they be affecting the gear ratios bearing in mind its a standard engine and i have no plan on changing it.
At the moment it has 165/65/13 and although they do fill the arches nicely but going by the manual i have standard size is 135/70/13, is that right?
Cheers  :)
Dave
Re: tyre sizes
« Reply #1 on: May 19, 2015, 10:01:53 PM »
Most of us with wide rims 5.5j x13 are running 165x55x13 checkout the chart below
mintex
Re: tyre sizes
« Reply #2 on: May 19, 2015, 11:12:45 PM »
ah ok cheers pete  they look like my next buy then  :good:
Dave
mintex
Re: tyre sizes
« Reply #3 on: May 23, 2015, 06:28:03 PM »
Are my standard 13" fiat wheels 5.5 wide?
Dave
Re: tyre sizes
« Reply #4 on: May 23, 2015, 08:21:41 PM »
Standard steel wheels are 4j X 13" ;)
mintex
Re: tyre sizes
« Reply #5 on: May 23, 2015, 09:51:48 PM »
ah, so i cant replace my 165/65/13 with  165/55/13's as they will not fit ?
« Last Edit: May 23, 2015, 10:00:41 PM by mintex »
Dave
mintex
Re: tyre sizes
« Reply #6 on: May 24, 2015, 09:38:13 PM »
This is how it looks with the 165/65/13's on .
Dave
mintex
Re: tyre sizes
« Reply #7 on: May 24, 2015, 10:30:11 PM »
Found this calculator and if i have it right i think they will fit but what do you think, yes or no??
Dave
Re: tyre sizes
« Reply #8 on: May 25, 2015, 09:12:41 AM »
If they don't rub inside the wheel arch especially on full lock or weight in the car leave them on, I presume you were going for the Mud Plugger look :P
mintex
Re: tyre sizes
« Reply #9 on: May 25, 2015, 12:01:21 PM »
haha  :lol: no they were on when i bought the car and thats when i checked what the standard size should be.
They don't rub, but  they get very close when turning and with weight in the car and as you say, looks like a 4x4 lol, think i will change them for some lower profile  ;)
Dave
Re: tyre sizes
« Reply #10 on: May 25, 2015, 02:13:57 PM »
With standard rims i would stick with 135x70/80x13's with standard tires fitted the ride will be allot softer than the 165x65x13's that are fitted,  if you fit Cinquecento/Seicento (fitment) 5.5j alloys the max size without body mods is 165x55x13's
http://club126uk.co.uk/smf/index.php?topic=2332.0
mintex
Re: tyre sizes
« Reply #11 on: May 25, 2015, 06:05:34 PM »
cheers bud, i will pop to the local tyre shop and have a word  :)
The main reason i want to change them is the gearing as these tyres have a larger rolling radius  :D
Dave
