Author Topic: bis exhaust  (Read 2970 times)
first car fiat
bis exhaust
« on: April 26, 2015, 09:49:44 PM »
Hi guys I had to get a new exhaust for my bis and the only one I could find was a stock original one. It's really bad quality and keeps braking at the welds. So does anyone know where to get a good quality sports exhaust. Much appreciated.
Re: bis exhaust
« Reply #1 on: April 26, 2015, 11:02:50 PM »
As far as i know there are no sports exhaust for the Bis the only way to go is to have one made, if you go on line and check out customized exhausts in your area,
The usual reason for the weld on the exhaust brackets breaking is that they are strained, when i fitted mine i bolted up the two down pipes on the head first, then if you look at the holes on the exhaust brackets they won't align with the holes with the captive nuts on the brackets that are attached to the engine, the idea is to re-drill the holes on the exhaust bracket so when there tightened up they fit without too much strain :)
first car fiat
Re: bis exhaust
« Reply #2 on: April 27, 2015, 06:22:04 AM »
That's the problem I had with the Brackets. My colleague is a welder/fabricator and he said he will make a new one using a motorbike can   :D
Bambino126
Re: bis exhaust
« Reply #3 on: April 27, 2015, 07:58:31 AM »
first car fiat
Re: bis exhaust
« Reply #4 on: April 27, 2015, 06:43:44 PM »
I have looked for that exhaust and can't find one anywhere.
Da Londo
    • Fiat 126 blog
Re: bis exhaust
« Reply #5 on: May 08, 2015, 10:05:18 AM »
I bought a sport exhaust once for a friends bis and I believe it's made for 500 Giardiniera.
