Author Topic: can I take my car the rmp indicator  (Read 2305 times)
baltunbas
« on: May 23, 2006, 10:00:29 AM »
I have a rpm electronic indcator for 4 cylinders engine
I take that but its not running
can I find a prm ind. for 2 cylinders
and I have electronic intigon but I take that it its not running
my idea is can I take electronic intigon the fuel expences is down
is my idea true or can I thake?
there is not I take lpg to my car because litter of gasoline aproximate 2 dolars
but liter of lpg is 1 dolars
can I change my carb whic mark and kind for the fuel expences is down
PaulB
« Reply #1 on: May 23, 2006, 03:36:26 PM »
If you have an electronic rev counter that can be selected to 4, 6 or 8 cylinders you can open them up and see the resistors used to make the switch. Then you can work out the resister value for a 2 cylinder engine and use a that.
I've no idea if it would be safe to use lpg in a 126, or where you would store the gas. The cost of converting may never be worth the saving on such a small engine anyway.
I'm not sure what you were trying to say about electronic ignition. It will make the car run better and therefore be more economical, but as these are not fuel injected cars, the saving is not great as you are stuck with the same old ignition curve.
You can swap carbs, but this is usually done to get more power, not save fuel. The easiest way to save fuel is to drive gently.
« Reply #2 on: May 23, 2006, 07:25:12 PM »
They run on LPG fine a friend had one, bottle in the back.
Now that is really being tight.
Plenty of rev counters for the 126 about.
