Author Topic: Door Window Swap One Piece to Two Piece  (Read 2110 times)
lancianut
« on: March 24, 2015, 09:39:13 PM »
Hey,
Can anyone advise if its possible convert a 126 door with a one piece window to a two piece version? I can see the mirrors need to be moved to the door however unsure if the quarter light frame jurt bolts in??
Regards Johnny
Re: Door Window Swap One Piece to Two Piece
« Reply #1 on: March 24, 2015, 10:05:16 PM »
Not so sure it's an easy swap. The quarter windows are bolted through the top of the door frame at one point and inside the door lower down. You'll then need the main window which goes up and down and the winder mechinism which is different to the EL version. This bolts inside the door at certain points which the single piece (EL) door won't have.
« Reply #2 on: March 24, 2015, 10:23:51 PM »
Don't think it a straight forward job as Gadge said :( They are two different doors the EL and ELX are smooth with just one swage line where as the older type have the insert panel :-
lancianut
« Reply #3 on: March 25, 2015, 11:39:18 AM »
Ah cheers I did not realise there was a difference  :o.
Presumably, even if I found 'early' doors to fit they would look out of place as the lower swage line would not match the front wings or quarters as they don't have it.
So....ultimately, if I wanted to do the conversion it would mean changing the rear quarters and front wings and doors for early ones? Is my assumption correct?  :cry:
regards
Johnny
« Reply #4 on: March 25, 2015, 05:34:07 PM »
Yes pretty much. If you google "126 EL" and say "126p" you'll see the difference. The front panel is slightly different aswell
lancianut
« Reply #5 on: March 25, 2015, 06:31:18 PM »
 8)
Thanks for clarifying my suspicions.
