Author Topic: Rear Side Window Hinge -Bis  (Read 2418 times)
punkydog
« on: March 08, 2015, 09:10:49 AM »
Hello,
I need one rear, side window hinge, un-faded, not the opening/closing latch - just the hinge for a Bis.
Alternatively the complete car set of four hinges and two latches.
Thanks, Brian
Brian
Re: Rear Side Window Hinge -Bis
« Reply #1 on: March 08, 2015, 12:25:09 PM »
Hi Brian, they don't have a hinge just two oblong rubber grommets in the window surround (body) that the tail of the two window bracket push into :headscratch:
126blackbird
« Reply #2 on: March 08, 2015, 01:09:31 PM »
Hi, I have a complete set, six pieces if you are interested
 Graham
punkydog
« Reply #3 on: March 09, 2015, 12:45:18 PM »
It is the plastic bits that attach through glass with a screw and push into the window surround I need, they sort of pivot so I thought hinge was the best term.
Brian
« Reply #4 on: March 09, 2015, 08:16:32 PM »
Just a suggestion, you might get away with using rubber wiring grommets ;)
« Reply #5 on: March 09, 2015, 08:58:36 PM »
punkydog
« Reply #6 on: March 10, 2015, 08:45:19 PM »
Thanks for that link, hopefully getting some s/h ones.
Brian
