Author Topic: Wanted parts  (Read 5677 times)
Kent126
    • Facebook Profile
Wanted parts
« on: January 28, 2015, 01:48:43 PM »
Hi guys,
    There are a few parts I need and I'm struggling to find them. Ideally if I can find them brand new somewhere that would be better. If not than decent condition second hand parts will be ok as long as they can be refurbished to a good standard.
If anyone has any lying around in good condition or knows where I can buy them any advice would be appreciated.
Fiat 126, 1974 accelerator pedal. Must be the type shown below;
Also need a fiat 126 wiring loom from 1974
Original rear plastic air vents from a series one car.
Tom
« Last Edit: January 28, 2015, 01:53:39 PM by Kent126 »
1974 Italian Fiat 126 TA
2008 Fiat Panda 100HP
Re: Wanted parts
« Reply #1 on: January 28, 2015, 06:03:58 PM »
The accelerator pedal looks like the standard one on the Bis ;D
Bar Vitelli
Re: Wanted parts
« Reply #2 on: January 28, 2015, 08:10:06 PM »
If not then Franco may have one but they are very expensive for RHD...repairing the one you have may be a more affordable option.
Every cloud has one...
Kent126
    • Facebook Profile
Re: Wanted parts
« Reply #3 on: February 03, 2015, 10:46:38 PM »
I will need to email him, everything pedal wise seems to be LHD on his website. How 'expensive' is expensive?
Anyone got a 'bis' pedal lying around?
Tom
Sent from my iPhone using Tapatalk.
poxxxy
Re: Wanted parts
« Reply #4 on: February 04, 2015, 02:03:11 PM »
Whats up with your own? They're fairly simple I believe...
drcdb15
Re: Wanted parts
« Reply #5 on: February 08, 2015, 12:37:32 AM »
Indeed they are, having taken two apart now to make serviceable - one from a Bis and one from an A/C, and from memory they are both the same. The one I have on my bench at present is the A/c one, and it's welded at both ends so full dismantling is not possible. However, the inner (moving) rod is located in the fixed tube with a small circlip at one end. This is easily removed and replaced, and when removed allows the inner rod to be moved relative to the outer tube. Lots of WD40, waxoyl, 3-in-1 oil or anything else that's runny is OK to get it freed up if it's rusty and seized. My personal regime is to use WD40 to get it free, hang it up vertically to aid distribution, flood the top end over several days with regular copious amounts of WD40, don't forget the drip tray underneath so you don't make a mess plus you can 're-circulate' the oil. When it's all free, then I do the same with waxoyl, to make sure the inner surfaces have some rust protection. But waxoyl will eventually dry to just the wax bit, which can be a tad sticky, so the final stage just before refitting to the car is to run in some ordinary lubricating oil - old engine oil, 3-in-1 or whatever, and then re-fit the circlip and re-fit the pedal to the car. Being horizontal in location, any surplus oil will usually stay in the tube ensuring the pedal operates freely, but for the first week or so of use just keep a rag or kitchen towel at each end to soak up any oil that spills out.
Marky
Re: Wanted parts
« Reply #6 on: February 08, 2015, 07:52:16 AM »
Try www.ricambio.co.uk
If they don't have your parts in stock, they can get them. Marky  ;D
....What if I told you..That the flashing lights on the side of your car.. are to indicate where you want to turn....
Bar Vitelli
Re: Wanted parts
« Reply #7 on: February 08, 2015, 08:40:00 AM »
Less than £100 for RHD. Depending upon what is broke it may be best to fix yourself.
sunriser81
Re: Wanted parts
« Reply #8 on: February 08, 2015, 10:47:14 AM »
Hi Kent126 Do you still looking for I-series complete loom as have got on stock. cheers.
126blackbird
Re: Wanted parts
« Reply #9 on: February 08, 2015, 12:35:41 PM »
Hi Tom, did you find an accelerator pedal yet, I think I may have one for a Bis
 Graham
DeVilleChris
    • Club 126 UK
Re: Wanted parts
« Reply #10 on: February 08, 2015, 03:49:01 PM »
I have an A/C one but I think it is probably in worse condition..
1979 Fiat 126 DeVille
1979 Fiat 900T Amigo
Bar Vitelli
Re: Wanted parts
« Reply #11 on: February 08, 2015, 04:02:44 PM »
Don't throw it away, Chris, if Tom does not want it I 'd be up for a spare! I think you might have the plastic air vents that Tom is after though from the car you broke?
DeVilleChris
    • Club 126 UK
Re: Wanted parts
« Reply #12 on: February 08, 2015, 07:20:23 PM »
Nope, they're already spoken for by OPD :)
Bar Vitelli
Re: Wanted parts
« Reply #13 on: February 14, 2015, 10:03:38 PM »
I've found the air vents on eBay Italy for EUR 40 - let me know if you are interested and I'll PM you the link.  ;D
Kent126
    • Facebook Profile
Re: Wanted parts
« Reply #14 on: March 11, 2015, 05:30:12 PM »
Hi Garry, are the vents still on ebay?
Graham, can you send me a pic of the pedal you have to [email protected]? Thanks.
Thanks for all the advice. I shall have another go and freeing the pedal. I have two. One is rusted solid, and the second is broken and needs welding.
Tom
