Author Topic: track rod end.  (Read 3495 times)
paul harbinson.
track rod end.
« on: May 17, 2006, 01:52:31 PM »
Gianni needs a track rod end.Having a bit of a problem with finding one as he's fitted with a steering box.(Hav'nt tried Malcolm fancy yet)
Dante Giacoso, pure genius!
track rod end.
« Reply #1 on: May 17, 2006, 08:19:54 PM »
Let me have the part number of picture I will look through my tons of parts.
Bruce
track rod end.
« Reply #2 on: May 17, 2006, 10:52:20 PM »
the part number for the bis track rod is: 7591300
track rod end.
« Reply #3 on: May 17, 2006, 11:59:44 PM »
I guess that it's probably the same ball joint fitted on the Fiat 500 which are more readily available?
paul harbinson.
track rod end.
« Reply #4 on: May 18, 2006, 07:50:14 AM »
It's the inner track rod end on the passenger side(don't forget it's left hand drive)
PaulB
track rod end.
« Reply #5 on: May 18, 2006, 08:33:48 AM »
Here's the aircooled inner tie-rod end (from axel gerstl) with part numbers - common to 500F/L/R and 126/126P to '78. Often on ebay, but only about £6 from AG
paul harbinson.
track rod end.
« Reply #6 on: May 18, 2006, 10:16:15 AM »
Cheers Paul have you got their number?
PaulB
track rod end.
« Reply #7 on: May 18, 2006, 04:08:24 PM »
https://ssl.kundenserver.de/shop.fiat500126.de/indexa.htm
Two things to consider: postage starts at 8 euro (its cheap when ordering  a few bits), and if you do use them, when you put in a postcode, leave out spaces as it doesn't like them - took me ages to figure out why it wouldn't accept mine. If you've not been to this site before... enjoy!
