Author Topic: Camshaft  (Read 2964 times)
Da Londo
    • Fiat 126 blog
Camshaft
« on: January 17, 2015, 12:05:46 AM »
I've learned a great deal about many thing here on the forum and one of 'em was that a 40/80 cam would also be called a 300 degrees cam (correct me if I'm wrong). But now I go on ebay and find a cam like this: 40/80 110* 7,60 lift. What is this 110* and is 7,60 okay for lift? The swiatek does 7,20. Ebay number: 231295716159
Da Londo
    • Fiat 126 blog
Re: Camshaft
« Reply #1 on: January 17, 2015, 09:34:59 PM »
Ah, Swiatek site back online. 110 degrees is Alpha angle.
 ??? What is alpha angle?
Piotross
Re: Camshaft
« Reply #2 on: January 17, 2015, 09:56:57 PM »
Kałuża has better camshafts than Świątek...
Da Londo
    • Fiat 126 blog
Re: Camshaft
« Reply #3 on: January 17, 2015, 10:07:29 PM »
You have a website for Kałuża?
Piotross
Re: Camshaft
« Reply #4 on: January 17, 2015, 10:55:35 PM »
Kałuża hasn't own website. Sometimes he doing camshafts - it's a strange situation.
I have some new camshafts of Kałuża project
Da Londo
    • Fiat 126 blog
Re: Camshaft
« Reply #5 on: January 17, 2015, 10:57:51 PM »
Can you give me the specs from that camshaft?
Piotross
Re: Camshaft
« Reply #6 on: January 17, 2015, 11:14:52 PM »
Camshaft 555
Lift cam 7.8 mm 7.8 mm
Valve opening 41 st. 72 st.
Closing the valve 61 st. 30 st.
arrangement of valves - a cold engine 0.15 mm 0.10 mm - a cold engine 0.15 mm 0.10 mm
Da Londo
    • Fiat 126 blog
Re: Camshaft
« Reply #7 on: January 18, 2015, 08:50:13 PM »
Can you explain what makes this one better?
