Author Topic: LHD to RHD  (Read 2237 times)
Gwtaylor
LHD to RHD
« on: January 03, 2015, 01:22:53 PM »
Since telling my mates I'm getting a little 126 my mate has jumped on the band wagon aswell and he wants one as well l. He's spotted a LHD but wants to know  if it's hard to convert a LHD into a RHD?
Datsun 120y estate
Austin A30
Hillman minx
Mazda 323 4x4 turbo
Clancy_Ryan
Re: LHD to RHD
« Reply #1 on: January 03, 2015, 02:33:53 PM »
Is there a point though?
Mine is LHD and there is no problem switching, besides with the car size you,re sitting in the middle of it anyway :D
Gwtaylor
Re: LHD to RHD
« Reply #2 on: January 03, 2015, 02:43:44 PM »
Exactly what I said
But he's found a cheap LHD but he likes the steering wheel to be on the propper side
What's involved
I'm assuming
New steering rack
Datsun 120y estate
Austin A30
Hillman minx
Mazda 323 4x4 turbo
Re: LHD to RHD
« Reply #3 on: January 03, 2015, 03:48:38 PM »
There's probably a lot more work involved than just changing the steering rack. Pedals, dashboard, speedo and there many other bits and pieces needed. Best to source a RHD donor car (unrestorable) for the bits if you want to go down the RHD route.
Re: LHD to RHD
« Reply #4 on: January 03, 2015, 04:14:14 PM »
Yes it's much more complicated. You'll need to cut holes for the steering rack and for the speedo cables and dash wiring. Then you'll have to fit the pedals over from the other side so you'll need to drill/fit new mounting points and you'll need a RHD Accelerator pedal as the LHD one is different. You will have to repostion the brake master cylinder as the brake pedal fits directly into the back of it (unless you can fashion some sort of linkage system up to the other side) then you'll need a RHD a rack (thin on the ground).
Gwtaylor
Re: LHD to RHD
« Reply #5 on: January 03, 2015, 04:16:04 PM »
Ha just showed him all the thread he's now sticking it out for a RHD model
Datsun 120y estate
Austin A30
Hillman minx
Mazda 323 4x4 turbo
