Well today I woke up to an email saying I had won an auction in japan, I haven't tried buying from there before but it seems the kei car scene has left a fair few ihi turbos lying around for dirt cheap... The model i've won is an RHF3 from a Daihatsu Terrios/Mira with model number VQ38. I've actually kind of fell in love with Daihatsu's whilst researching small engine turbo... 3 cylinder 12 valve engines
. The Mira Avenzato is a nice looking car to for sure although a tad rare. Charade GT turbo could be on the cards though (8:1 compression ratio). Then theres the Renault 5 GT Turbo (7.9:1 compression ratio).
So specs on the EF-RL engine this came from in a Mira:
EF-RL 3-cylinder DOHC
Turbo: IHI RHF3 VQ38
Compression Ratio: 8.5:1
68.0mm x 60.5mm (Bore X Stroke)
Bore stoke ratio: 1.12396694214876
659cc
64bhp (48kW) @ 7500rpm
74lb/ft (100Nm) @ 4000rpm
Electronic fuel injection with turbo intercooler
Rack and pinion power steering
4 Wheel Drive - 5 speed manual
Overall length 3295mm
Overall width 1385mm
Overall height 1450mm
Wheelbase 2300mm
Kerb Weight 730kg
I'm waiting a reply from Mike @ Ferriday Engineering regarding decompression plate options to perhaps try and aim for an estimated lowered compression ratio of 7.9:1 from both a 8.6:1 standard bis head and a 9:1 "big valve" cc700 head (which I have installed). This will allow more pushing more boost without raising the effective compression ratio to dangerous levels (12:1 is generally recommended).
Theres always the option of perhaps skimming some of the piston top. lol.
I'm also looking for someone who works with copper in order to produce a headgasket to my own template... i've been just generally disappointed with the 3-4 offerings i've seen of standard gaskets and the one copper one I have when put against my engine could be better. I've sent the drawing to the SS guys but not many people take on copper... i'm also reading alot of conflicting information regarding copper headgaskets against perhaps a composite kevlar headgasket being a better option especially without having the block surfaced also. Surface finish of the metals I guess also plays a part in how well they will seal!
I bought a TIG welder wonder machine in hopes to get fabricating a stainless exhaust for the BIS so I can continue to drive it around while I source bits and pieces but looks like i'll be trying to diagnose and fix that before I can begin to fabricate anything at all. I had prices back for laser cut exhaust flanges in 10mm stainless and they are a little steep so i'm considering 7mm stainless flanges or mild steel flanges to perhaps keep costs down. 10mm would be better though.
